Started doing a little inspecting of my 'new' 304A.
compression #'s aren't great but then I realize I'm used to higher compression duel overhead cam 4 cyl engines. So...
Engine cold, on a stand, carb removed. Engine hasn't run since last spring.
Dry: 8) 100 6) 120 4) 99 2) 100 1) 107 3) 99 5) 95 7) 99
Wet: 8) 140 6) 165 4) 145 2) 140 1) 125 3) 115 5) 110 7) 115
These numbers indicate some ring wear. I'll do a leak down test as soon as I borrow the tool.
But are these numbers reasonable for an old/cold engine? Are those compression numbers worth installing or do I already know I need to at least re-ring the pistons. What is the minimum acceptable compression psi? The FSM doesn't say anything about this?
Considering the factory sticker on the valve cover I'm assuming this engines never been apart. There's evidence of the rear main seal leaking and at the valley pan so I'll wanna replace those for sure.
