Jeepmb
Mornin' everybody,
Need a little help from from those more experienced than I with carbureted engines. I am getting what appears to be a steam rising out of the intake manifold after the engine is shut off (full operating temp). It can be seen by removing the air cleaner and opening up the throttle on the carb.
In more detail:
Im working on a 1976 Scout II 345 4-speed with an edelbrock 4 barrel 1406. This truck has been a little abused in the past, and ive spent the better part of a year just working on getting everything working as it should. It runs great on the road, smooth with plenty of power. I was diagnosing a hot start issue when I discovered the steam.
In addition, about a week ago I did a coolant flush (non-pressurized water + flush solution) and changed the thermostat. The thermostat I found broken in 3 pieces and completely stuck closed
. But from being broken, coolant flowed freely and the engine never got up to operating temperature. After replacing the thermostat, I finally now get the engine to warm up properly (It was bad enough I thought the temp gauge was broken before the change).
So is this light "steam" rising from the intake something to be concerned about?
As you can imagine, my worst fears are coolant leaking into intake, and fuel vaporization, but my exhaust is clean (for a 37 yr old truck) so I am hoping i'm just paranoid.
In more detail:
