Been kicked around a little and even discussed recently on another board.
The one I use is in the FAQ under parts required. It's from JTR and cost about $75.( I now carry them in stock in the machine shop forum)
There are several alternatives to that.
If you are just looking to have a VSS signal to get rid of a VSS light then just about any signal will do that.
If you want the speed to read fairly close to actual on the WinALDL dash..then that will require the right VSS (and a calibration module to compensate for gears and tires) Adjusting for gears and tires is not an option in these ECM's.
These have not been proven yet for proper signal so it's on you till they are.
This will be your cheapest conversion.
Looks to be the simple driveshaft add on for cruise controls.
Just use the right number of magnets for the number of pulses required.
Ours shoud be 2.
If my audiovox CC came with one in the box then I will install it and let you know. I just run the input off my JTR VSS so I never tried to install it!
RPC-250-4165 $19.95
Estimated Ship Date: Today
Brand: Rostra Precision Controls
Product Line: Rostra Vehicle Speed Sensors
Number of Wires: 2
Quantity: Sold individually.
Notes: Magnetic pickup style.
Vehicle Speed Sensor, 2-Wire, Magnetic Pickup, Universal, Each
This is close to what I am using but mine is 7/8 inlet and outlet.
Still should work if it's the right number of pulses.
RPC-250-4153 $42.95
Application Show All
Inlet Attachment: Male threads
Inlet Size: 7/8-18 THD
Outlet Attachment: Male threads
Outlet Size: 5/8-18 in.
Number of Wires: 2
I got this one with my Audio Vox cruise control and will try to mount it this week and see what the signal reads.
The obvious answer is use 2 magnets and get 2 pulses per revolution.!!
Google...
The Controls: JCW sent me a small control panel that is surface mounted and could be placed just about any where. That part number is 204-4110, Click here for picture of the controls.
The Cruise Control was ordered from J.C. Whitney, P/N 78DN7618F.
The Mfg. is SCS/Frigette and their P/N are listed below:
SCS 4365 Cruise Control $229.95 (4/99)
208-3609 Speed Sensor
From John N.
Hey I found one that is cheap and looks like it will work.
Looks just like the one from summit that was the Rostra brand only the VSS is metal instead of plastic.
I got it from a company called Jackson's Complete Auto Care. The part # is a 208-3606. I don't know the brand, nothing on the package for brand name either.
I'll try to post some pics when I can. It comes with the adapter cable and wire plugs and a bracket for the cable that holds the add on CC cable at the carb/TB.
I didn't check to see what the complete CC set up would cost but the VSS was $26.50. Not too bad. I will wire it up tonight and see what it does. If it works I'll post the contact info for Jackson's. Maybe even get a brand name and cut out the middleman and get it even cheaper.
Couldn't wait any longer to hook up the VSS so I did it. Only took about 20 min after getting my stuff together.
The unit actually fit on the other side of the body. The outside part. There is a hole that the speedo cable went through. The adapter cable is the right length to put the VSS on the outside. It went between the trans and the VSS. It actuallly makes the wires easier to follow the speedo cable up to the firewall. ( I'll get some pics soon.)
Test drove for about 20-30 minutes and no VSS code or SES light. Makes me very happy not to see that light,especially at night. Much easier on the brain too, not trying to guess if it is something wrong or just the usual VSS code.
Exhaust doesn't seem to pop as much when slowing down either.
You can find everything you need to make your speedometer read correctly
HERE from tranny gears to ratio adapters like IH used. Even if you changed tire sizes.
They also carry a VSS but it's 8 pulse. So it will read double.
