Scout II Power steering pump removal help
Discussion in 'General IH Tech' started by Tremor, Sep 17, 2020.
  1. Tremor
    Tremor Farmall Cub
    Jul 29, 2020
    54
    33
    Hey everyone, just wondering if anyone knows how to separate the bottom mounting bolt from the power steering pump bracket? Sorry if this seems like a dumb question, I'm pretty new to this and could find anything but a partial diagram in the shop manual. labeled in the photo below.
  2. theloneduck
    theloneduck Binder Driver
    Nov 24, 2013
    594
    114
    Arkansas
    It’s been a while since I replaced mine. Is that the bolt with the collar you have to slide out to remove the pump?
  3. winchested
    winchested Dreams of Cub Cadets
    4,254
    1,732
    There is a little sleeve on that you remove with a small screwdriver. That isnt a bolt it is a stud into the pump, and the two studs hold the pump into the Reservoir housing.
    Mark Aycock likes this.
  4. rustfreeTX
    rustfreeTX Binder Driver
    Apr 5, 2004
    804
    91
    Austin, tx
    A word to the wise, don't pry against that mounting bracket too much. It's cast and it's easier to break than you think. There are steel replacements available if it does break.
  5. J.J.
    Dec 14, 2003
    6,212
    3,580
    Castalian Springs, TN
    As mentioned there is a small metal sleeve in there that must be carefully pried out. Make sure it is as clean as possible and even some liberal doses of Kroll or the like will help. I just removed one a couple of days ago, and it had been partially squeezed at some point in its life that it was crushed around the threads of the stud enough that it had to be unscrewed instead of pried.
    Best of luck!
    JJ in TN
  6. mporter52
    mporter52 Binder Driver
    May 17, 2005
    688
    75
    San Antonio, TX
    Take the whole bracket off, much easier to get too.
    J.J. and MrKenmore like this.
  7. J.J.
    Dec 14, 2003
    6,212
    3,580
    Yes, thats true. Also might want to go ahead and replace the hoses since you've got it apart..
    JJ in TN
