You can't see it because it's hard to see. The correct port is on the front of carb base, directly under the float bowl. Look at your diagram. There is already a hose attached to it apparently. It goes to toward the back and out of the picture. I'd assume it must go to a thermal switch, also indicated in the diagram as an optional case. They hose coming from the distributor must attach there. See the pic below. E and D correspond to the hose labeling in your factory diagram. Make sure that Hose 'F' (not seen in the pic below) is also connected where it should be. Hint: go buy some vacuum hose.
OPTIONAL config: Since the hose routing described above is only used on AC equipped engines, and your AC was obviously yanked out, you could just disconnect 'D' from the temp switch and connect it onto the distributor's Vac Advance. In other words, remove your existing Hose 'E' and reattach hose 'D' there. This basically turns Hose 'D' into a Hose 'C'.
Be sure to LEAVE HOSE 'D' CONNECTED AT the CARB. If you pull the hose off that nipple it's a pain to reconnect later without lifting up the whole carb a little. Not much "finger room" under there.
?? He is not running a 2300. The engine still has the stock 2210 on it.
VAC ADVANCE HOSES FOR TREMOR'S 2210 CARB:
OPTIONAL:
