Removing a leaf (or two) made the difference I was looking for when I installed my 4" Triangle spring packs. Below are the write-ups I posted. Hopefully, you can try this and then get the fridge out of your Scout!
OK, the 4" Triangles I got from Damian are finally installed. Per all the great comments I got from many (see below); I did NOT need a new pittman arm, I did NOT need a longer driveshaft(s), nor new brake cables or shocks, etc. No castor adjustment, either.
Triangles leaf packs are 6 for the front, seven for the rear.
The spring packs were "modified" by Yours Truly in the following ways:
Rear packs - I removed the first three shortest leaves of the seven, reducing it to only four leaves.
Front packs - I removed the third leaf and added it to the rears, so each pack now has only five leaves.
The logic is that my SII is comparatively light, and I rarely carry a lot of people or cargo, and never tow anything.
All packs got new poly bushings liberally coated with that sticky silicone grease that came with them, as well as extra spray of silicone lube spray. I applied this to all the bushing parts, spring eyes, bolts..everything. I don't want any crickets in my Scout!
Also, I ground down the edges of the ends of the leaves where they contact the leaf above them. They were kinda rough and I didn't like how they might cut into the leaf that they support.
Ride - The ride is stiff and bouncy, as predicted by many. I would not compare it to a "dump truck" or a "buckboard", as I've seen some mention. Our dirt roads (and my driveway ) are fairly rough; the Triangless seemed to really like that. Uneven pavement seems to inspire what Damian's wife calls "the jiggle factor."
Flex - untested. To be continued... I can't wait!
Handling - As Baradium mentioned, it certainly handles a lot better - no body roll here! IH - there is no substitute!
Looks - Cool...very cool. I can see fitting 32" tires down the road; possibly 33"s...
After driving it for a few months, to let the springs break in, I'll post more to give an update. So far, so great.
I need take a moment to throw out some BIG THANKS (AKA mad props) to a few fellow Scouters. (Sorry to all I forget...) I appreciate all the constructive advice!
BigRigg
tdc (AKA Rick in Rockfield)
Mark Ashford
Chris Pucci
Erik VR
Carl Wiese
WesV
Baradium
Gary Billings (as always)
And here is the "Update":
As per my previous post, I removed two of the seven leaves from the rear pack, and removed one of the six leaves in the front, so there are five leaves in each pack.
So, what is this like on the road?
Sweet as candy on a hot summer day!
OK, it's a little on the stiff and jiggly side; kinda like riding in a SUV with brand new, heavy-duty lift springs. I guess they'll break in andsettle down a little bit as I continue to drive it, and drive it I will.
I love this thing even more, now. It handles better, and I love the way it "launches" over obstacles, dips, spped bumps, etc. Very rockin'!
For a while, I may let a few lbs of air out of the tires; dial them down to 25 psi for a while. They're at 32 all around right now.
I'm so glad I did this mod.
Thanks again to all the encouragement and advice.
HTH,
