We used to have a thread about Dana Axle Identification in the Knowledge Base forum, but I can't find it now; it seems to be missing. Luckily, I copied and saved the main information long ago and have reprinted it below:That is a Dana 44 by the shape of the cover. Besides the tag (which I do not see) Dana stamped on a Bill of Materials (BOM) onto an axle tune (usually the right outer facing tube) but you will have to scrape to find it. If you desire to scrape for it, and post it, I have Spicer books and can decode the number and tell you what ratio it left the Dana factory with and whether or not it had a limited slip. This may be redundant information and not worth the effort.
That number falls below the range of BOMs for 1970, indicating it's earlier. I have books from '67 up and '60 down. I have been searching for years for one from '61-66. I have bits and pieces from the era. Based on the number, I'd say it's a Dana 27 built prior to 1967.
I forgot about the date code, 12-18-8B5, which decodes to December 18, 1968, plant and shift code B5. Should show up in my '67 book but doesn't and I think I know why.
Starting in 1967, Dana developed a hybrid axle for Scouts. They were used on '67-71 800 V8s (also used for the 6-cylinders when they debuted in '69). They combined a Dana 30 center section with Dana 27 outers. Though the ring and pinions are similar, 27 to 30, the 30 had a beefier case and slightly larger pinion bearings (IIRC). The hybrid was wider than the standard 4-cylinder axle and had thicker tubes for the extra weight of the V8. It was also set up with the steering system used for the V8s, which put the steering box outside the frame rather than inside.
As I dug into this a little, I made a strange discovery. It turns out that somebody I know emailed me with the same BOM about a year ago, but with a 1967 date code. I couldn't decode it then either! I know the owner of a '67 Scout V8 and I have emailed him asking for his BOM and date code. If it shows that BOM, then we know yours is a V8 axle. The '67 listing for the Scout shows a Dana 30 with a BOM of 602951 (ratios codes varied), so either that is the hybrid or the standard axle. It's a little odd that the D27 isn't listed in the '67 book.
As an FYI, IH had been building two front axles for the Scout from '67, the D27 for the fours and the D27/30 hybrid. When the sixes debuted in '69, they used the hybrid axle and V8 chassis. To homologate production, it was decided in February of '69 to use the hybrid axle for everything. The Product planning books say implementation started in April of '69 but that it would take a while to purge the remaining D27s from the system, so apparently you saw both types coming of the line for some period after April.
in looking at this era 800, 800A, 800B, I find three BOMs all listed as "Dana 30"
'67-69- 602951
'69.5-70- 603144
'70.5-71- 603184
Anyone with a '66-71 800, 800A or 800B, chime in with your front axle BOM (right tube facing forward, and help figure this out.
'67-69- 602951
'69.5-70- 603144
'70.5-71- 603184
The 3.73 ratio 30/27 (per LST) axle on my '71 has: 12 21 184 C5 and 603184 2
Jim, yours is information which needs to be in the Knowledge Base section, IMHO. BTW, Last time I looked for the old article (from the old site) on Axle ID, I couldn't find it. It may still exist as a standard thread, but seems not to be in or to have its link in that section anymore.
.Good the see the numbers line up with the Spicer book on your '71. Was it a four, six or V8?
Wanted to pass on a little more information about my front axle that I was able to get directly from technical assistance at Dana Spicer (build of materials number 602894 1/ Build date number 12 18-8B5). I was told that the BOM (and identical 602894 2 BOM) were originally released from the factory on December 23, 1965 and were a straight Dana 27 axle with a 4.27 gear ratio. However, that series of axles was "rewritten" May 8, 1968 due to a change in the carrier cover bolts.
That would account for why Jim was unable to find this BOM in his below "1960 and above 1967" reference material as well as explain the confusing later build date of 1968. So long story short, if your scout has a front axle with a BOM of 602894 1 or 602894 2, you've got a plain ol' Dana 27 axle from a run that started in 1965 and went through 1970. I may be the only one who finds this interesting, but I enjoy finding out all I can about my Scout. It's a bit like researching family history even if you find out you're not related to George Washington or don't have a unique axle under you.
You see, that's what's hard about my build here. I've got a V8 (or straight 6) frame and body, Dana 44 rear axle and this Dana 27 front axle that I bought from the grandson a scout-enthusiast gentleman whose memory is failing. My guess is that the 27 came from a 4-cyl. 196 scout. I'm just hoping I don't tear up the D27 when I eventually put the in 304 V8.I presume your application is that... a straight four-cylinder 800?
