Reading codes on IH electronic engines
Chris Joens
Jul 11, 2006
76
Hartley,TX
To read codes ,Turn key on but do not start engine,press engine diag. button ,After several seconds oil/water light will flash once, then the warn engine light will flash a series of flashes seperated by pauses for instance 1 flash pause 2 flashes pause 3 flashes would be code 123 if there is more than one active code the oil/water light will flash once between codes .After active codes are displayed oil/water light will flash twice then inactive codes will be displayed ,after all codes are read oil/water light will flash 3 times.
active codes cannot be cleared until the faulty condition is corrected. To clear inactive codes, Press engine diag. button and hold down, turn key on but do not start, depress accelerator pedal all the way to the floor 3 times ,turn key off ,release engine diag. button ,wait 20 or 30 seconds to allow ECM time to clear codes.
111- no errors detected
112- electrical system voltage B+ out of range high - charging system fault
113- electrical system voltage B+ out of range low- low battery or wiring fault
114- engine coolant temp signal out of range low-ECT circuit or sensor short
115- engine coolant temp signal out of range high-ECT circuit or sensor open
121- MAP signal out of range high-MAP sensor or circuit short
122- MAP signal out of range low-Map circuit short low or open
123- Map signal fault- MAP sensor or hose plugged
124- Injection Control Pressure signal low-sensor or wiring
125- ICP signal high
131- accelerator position signal low
132- accelerator position signal high
133- accelerator position fault
134- accelerator position and idle validation disagree
135- Idle validation switch circuit fault
141- vehicle speed signal OOR low
142- vehicle speed signal OOR high
143- wrong number of CAMP signal transitions per cam revolution
144- CMP signal noise detected
145- CMP signal inactive while ICP increased
151- Barometric press signal OOR high
152- Barometric press signal OOR low
154- Air inlet temp signal OOR low
155- air inlet temp signal OOR high
211- Engine oil pressure signal OOR low
212- Engine oil pressure signal OOR high
213- remote throttle signal OOR low
214- remote throttle signal OOR high
215- vehicle speed signal OOR high
216- electronic pressure govorner OOR low
221- cruise/PTO control switch circuit fault
222- brake switch circuit fault
223- VPM not communicating with ECM
224- Flash memory loss
225- EOP sensor signal fault
I'll put more codes in later
Chris Joens
Jul 11, 2006
76
Hartley,TX
neverenufhp
is there a certain code you are looking for? I am not familiar with the display that shows the codes . but it would not surprise me if the codes are the same . from 99 to 05 I was shop foreman/Mechanic for a company that had a fleet of international trucks ,most had DT466e engines .
Chris Joens
Jul 11, 2006
76
Hartley,TX
more codes
226- electronic pressure governor OOR high
231- ATA data communications link error
232- unable to forward ECM message to ATA DCL
233- tach buffer is inactive
234- unable to forward ATA message to ECM
235- VPM/ECM DCL fault
236- engine coolant level switch circuit fault
241- injection control pressure regulator OCC self test failed
242- FDCS circuit to IDM OCC self test failed
nevrenufhp
Apr 8, 2005
44
Raymond, WA
I'd have to pull the codes to get any numbers. There's 3 trucks at work with 2 "soft" codes each(no check eng. light). I remember it's real easy to get them too. With the key on/engine off, press Cruise power on, and resume at the same time.
Joe p
Aug 29, 2005
sacramento ca
nevrenufhp said:
Got some for the newer ones that print the code on the dash display(2000-2006-ish)?
on the new trucks ,i.e 4300, with the dig. display you need to have the parking brake on, in park if automatic, then hit the cruse/on and resume buttons at the same time.
Chris Joens
Jul 11, 2006
76
Hartley,TX
the trucks I have codes for are 2000,4000 and 8000 series trucks with DT466 and DT530 engines all the codes are 3 digit numbers.
Chris Joens
Jul 11, 2006
76
Hartley,TX
243-IDM power relay(MPR) OCC self test failed
244-Eng to Trans data link self test failed
245-Exhaust pressure regulator self test failed
246-Engine fan self test fault
251-Glow plug control self test failed
252-Glow plug lamp self test failed
253-Fuel injector sync. circuit self test failed
254-Output circuit check out of range high
255-Output circuit check out of range low
256-Radiator shutter enable OCC Fault
262-Change oil lamp OCC fault
263-Oil water lamp OCC fault
265-Vehicle retarder relay OCC fault
266-Engine warning lamp OCC fault
OCC = Output circuit check
Jerry J
Oct 6, 2012
Brookville, PA
I am helping a friend on a 2000 International 4000 DT466e. It starts up just fine in 2 or 3 seconds, It idles at about 500 RPM, when you step on the accelerator the RPM's go up to about 1200, then drops back to an idle and stays there. At this point the pedal has on effect. Pulled the code #134 said APS/IVS-- APS singal and IVS disagree. I replaced the APS/IVS switch, things did not change. I measured the voltage, 5 volts was present. Any help would be appreciated.
Drifter
Jul 30, 2012
91
Athens, Texas
Well I hate to state the obvious but when comes to electrical it can only be 3 things, sensor, wiring, or computer. You said u already replaced the sensors so now u need to check wiring find the pins on the computer harness that go to the sensors and test for resistance in the wires. Then make sure ur getting 5v and a good ground to both sensors. If the wires are good and the power is good and the ground is good and the sensors are new, then it has to be the computer. Good luck.
Binder TV
Binder TV
