Paul LaBar
All,
Here goes - I have a 304 that's running on quite well on 7 cylinders. (That makes it a 266 BTW. Tom Walker would be so proud . . . I digress).
Anyway, the plug in #7 is oil fouling. The vacuum gauge consistently drops 2-3 pounds on that cylinder, and I haven't had time to do wet and dry compression tests to help me diagnose whether the problem is in the top or bottom end of the engine. I know that in the long run something will have to be done, but for now I'm wondering if there's a quick 'n dirty fix to alleviate the problem a little AND could there be any negative ramifications of getting this cylinder to fire in a degraded state? The manual suggests that a temporary fix to oil fouling is running a hotter plug.
I just put a completely new set of Autolite 303's (Oops! not 85's), wires, cap and rotor as part of a tuneup. The old plugs (except for this one looked pretty good). So, I know the spark is strong. I also have added some Sea Foam to the oil and run about 1/3 can through the carb to clean things up that might be carboned or sticking.
I know I should probably just ignore the problem for the time being since the engine works great otherwise, but I just can't help trying to cover all the bases (that the pocket book allows).
Thanks in advance for your help!
Paul
Paul
