bdubb
I am in the process of replacing the valve cover gaskets on my 73 scout 345. I figured while I had them pulled I would clean out the oil return holes. I am assuming that they are the two holes at either end of the bottom of the head? If this is correct are they the only ones and what is the best way to clean them out. Any other things I should look at while the covers are off.
Thanks Brian
Thanks Brian
