"Not actual beadlocks"
Ricky77
High Wheeler
Apr 27, 2003
1,333
Albuquerque, NM
You guys will love this. This guy down in Texas had a set of beadlocks cut on a plasma jig (that computer programable one) out of some steel plate. The shop that did the cutting also welded them on his rims. So he takes the rims and newly mounted 35's home and bolts them to the truck. With new tires and newly painted-beadlocked rims he figures to go to the car wash and clean it up. You know how it is when you get something new...... Well on the way home he gets pulled over and the officer tells him that it is illegal to run beadlocks on the street, and in Texas it is. Well this ol boy tells the officer he knows that it's against the law to run "actual" beadlocks but these are "posers" and then points to the rims. At the 12 o'clock and 6 o'clock position on each of the outside pieces of the beadlocks he had used a metal stamping kit to stamp, get this.
NOT ACTUAL BEAD-LOCKS
NOT RECOMMENDED FOR OHV USE
The officer told him they looked great and to have a nice night. I had to laugh.
Ricky 77
Ricky77
High Wheeler
Apr 27, 2003
1,333
Albuquerque, NM
budget76 said:
haha thats a good idea for all the hardcore guys. might not be cheap though :rolleyes:
Wrap your mind around this. Total cost for the beadlocks and labor was less than 200$. So you could do this with your existing rims. Man I love down home thinking.
Ricky 77
Mark Ashford
Moderator.. or something
Staff member
Moderator
Jan 30, 2002
3,989
Woodinville, Wa
Ricky 77
He got a real deal on the work then. Expecialy now with the cost of steel as high as it is, there is about $200 worth of just steel. Cutting bead-lock rings is also wastefull of steel (allot of material drop) so unless you have other small parts to fill in the gaps your throwing alot of money away. Plus plasma time is not cheap, unless you get buddy deals. Then there is a few bucks in hardware.
Now you *can* make them cheap. Use a hand plasma and a template, drill the holes yourself. Basicaly substatute time for specilized equipment.
Last I checked you could get weld-on beadlocks for between $80 and $100 a wheel, there are some cheaper "circle track" locks in the $50 ea. range, but are not as tough as some others out there.
Just food for thought, I looks at haveing a local shop here burn me out some rings, but when it was all said and done, it wasn't much cheaper than buying them. A little, but it would have been more to hassel with than picking up a phone and ordering them.
I like the stamp though :D
75ScoutII
Jan 9, 2004
380
Phoenix, AZ
For 60 bucks a peice, you can get these at any discount tire store.
www.uniquewheel.com
SERIES 252
Black "D" Window Street Lock
15x7, 15x8, 15x10, 15x12, 15x14,
16x7, 16x8, 16x10, 16x12
I've been stopped by DPS (highway patrol), and both Phoenix and Glendale PD.
Mark Ashford
Staff member
Moderator
Jan 30, 2002
3,989
Woodinville, Wa
Those real Bead-Locks or fakies??
Looks like "bead-lock looking rim" not real bead-locking rims were the rim unbolts and pinches the bead to retain it.
If they are real however thats a KILLER price....
75ScoutII
Jan 9, 2004
380
Phoenix, AZ
Doh,
The entire post is about making fake beadlocks.
Yes the picture is of a fake beadlock.
Jason.
WesV
Y-Block King
Dec 10, 2001
3,745
Harrisonburg, VA
No the entire post is about making real beadlocks look fake so that they can pass as road legal.
TCRIMSONK
Jan 10, 2005
264
Frederick, MD
Does anybody know if Tire Screws are legal? They are an affordable alternative, and just screw through your stock rimms into the rubber.
