oldironoffroad
High Wheeler
Well figured while I am tinkering around with Nick's rig I might as well go ahead and start a build thread. The overall goal for Nick's rig is to have a solid dependable rig that could be daily driven. Plans for it as of now is to upgrade to power steering/ brakes. Install the fresh 304, and swap in/ go through the dana 44's Nick sent with the rig. Here are a few pics.
Nick had the engine rebuilt 9 years ago I believe so I was concerned that there nay be some surface rust inside the cylinder. Due to a busted exaust manifold mount we are going to have his fresh head guts swaped into another head so while the head was off we got a good look into the cylinders and they look perfect.
Since it has been sitting for so long alot of the engine bolts are amiss so while I am waiting on a SS bolt kit to arrive I went ahead and rebuilt the oil pump and some other stuff.
The rebuild is fairly easy , just follow your manuals specs for clearences.
gear to body clearance
When I rolled the engine on its side to install the oil pump I noticed that where the side seals were supposed to be there was a glob of silicon so I pulled the main rear bearing cap to find this. Now the silicon might have sealed for a while , but oil would have eventually worked its way through and leaked so after some cleaning some assembly lube on the bearing and the cap torqued to spec I installed the proper side seals with a dab of type 2 sealent to help them slide in.
oil pump istalled
timing cover cleaned up painted and ready to go back on.
It will still be a week or so before I really get rolling on this one , I just wanted to show Nick what was going on so far.
oil pump istalled
