codeman
While I'm still a good ways out from installing my drive train, I'd like some opinions/information about my "new" engine. I'm doing a frame off on a 78 Scout II, going from auto to 4-spd., SOA, R/S, 2.5" body lift, and on and on.........
I purchased a 1975 392 that is completely rebuilt. It was built by a now retired IH diesel engine mechanic to use in a T-all for pulling events. He completed it in 2000, filled it with oil and primed the system. For some reason, he never installed it and it has never been started. I have spoken with a good friend who runs the machine shop at the IH dealership. He has assured me the parts and workmanship are top-notch!!!
I want to "tweak" a few things before installation: port match exhaust, grind down air tube "bumps", BBC valve springs, verify cam & timing, change oil pick up tube & filter mount, etc. Since the engine has been sitting so long, with oil in it, I'm sure the oil has gotten funky. I don't want to move it back throught the engine. So, I'll drain it. To lube the bottom end of the bores, should I add a couple fresh qts. and rotate the assembled engine on the stand before taking the heads & base pan off? Or, should I add more oil and prime the entire system again? I'm concerned about the bores being dry and moving the pistons. I know I can oil the top end when remove the heads.
Anything else I should do or look for while its on the stand?
