MPFI IAC Valve Wiring
Binder TV
deadeyedan18
Nov 12, 2018
So, I'm working my way through putting together a mpfi system for my truck and I'm down to wiring it all up. I'm using the holley throttle body off the late 90's dodge pickups with the integrated IAC motor. Does anybody know if the Holley/Dodge IAC motor is wired up the same as a 454 or a 350 tbi IAC motor? Or should I just swap it out for a GM IAC motor?
deadeyedan18
Nov 12, 2018
I found the dodge wiring diagram and it is pretty unhelpful. I guess replacing it is the most sure way to get it right. Thanks much for the help.
mallen
Dreams of Cub Cadets
4,301
It's looks like it could be a 2 phase stepper. There's really no reason to think the two would necessarily be the same. The drivers are matched to the requirements of the motor.
Bill USN-1
Moderator
Staff member
Moderator
17,184
Except if you look at my early MPFI write ups you will see i already used the Dodge throttle body and rewired the IAC to work with the GM ECM.
But, I don't remember if I actually documented the wiring changes I made.
Some times I just get too busy building and forget to document everything.
But it can work.
it would still be easier to just swap the IAC to a GM IAC and not worry about the wiring changes.
Or just use the GM throttle body without the injector pod on it as i also showed.
mallen
4,301
But it can work.
That's actually suprising. Maybe they use the same components in the pcm
