IH 7.3 to IH 5spd?
Binder TV
Jeff Joyce
Binder Driver
Jun 24, 2003
732
Raleigh, NC
I've been scratching my head (and searching the net), trying to figure out how to mate a 6.9/7.3 block to a SAE (I think SAE#3) bellhousing with an IH 5spd.
What I've found is that some 7.3s in medium duty IH applications had AT545s mated to them. I'm relatively confident the AT545 has a SAE#3 bellhousing pattern. This makes me believe that there's a flywheel housing for Ford transmissions (ZF/E4OD pattern) and there must also be a flywheel housing for an SAE pattern.
If this is true, you should be able to bolt a 7.3 block to any older 5spd (IH, Spicer, Clark, etc) using this medium duty application flywheel housing and a SAE bellhousing.
Then there's the flywheel and clutch setup, but I think I can figure that out if I can get the engine bolted to the trans.
Do any of you guys have any info on this? If so, point me in the right direction!
-Jeff
Eric VanBuren
Lives in an IH Dealership
May 7, 2004
6,011
Maple Valley , Wa
In Ford apps they used a 460 pattern housing and on the MD IH they used a SAE housing for the rigs with the Allison but I can't tell you the pattern# but they are 545's.
Jeff Joyce
Binder Driver
Jun 24, 2003
732
Raleigh, NC
Well, from everything I can find, the AT545 has an SAE#3.
I found this thread that implies that all IH 7.3s had a #2 flywheel housings and there's a #2 to #3 adapter to enable use of the AT545 http://www.thedieselgarage.com/forums/showthread.php?t=63720
So, an SAE#2 or #3 bellhousing/trans should work if you can find the right parts (i.e. flywheel housing/adapter) and correct clutch setup.
FYI, I'm trying to figure out how to mate a 7.3 (preferably from a Ford donor) to a T-36.
CareyWeber
Diesel Herder / Moderator
Staff member
Moderator
3,814
Ridgeway, SC
Jeff,
I think that the back of the block mounting surface on the 6.9/7.3/444 engines whether in a Ford or IH/Navstar application are the same. What is different is the adapter that is bolted to the block.
You'll need to find an adapter from a IH/Navstar truck and bolt it to the 7.3. I'm not sure if it's SAE 2 or 3, but this chart should help.
There are lots of IH S series trucks out there that used the 6.9/7.3/444 engines. The newer trucks like the 4300/4900 may have the six ot seven speed tranys that would be nice IMHO.
Carey
Jeff Joyce
Binder Driver
Jun 24, 2003
732
Raleigh, NC
I think the flywheel housing (adapter) on the back of the 6.9/7.3 is an SAE#2.
On a similar topic, does anyone know if the Spicer 3x5x transmissions have the same bolt pattern as the IH T-3x?
Eric VanBuren
May 7, 2004
6,011
Maple Valley , Wa
Well the half a dozen S-series and 3x00 rigs at work with the 7.3 and 545 have no additional adapters, just the bellhousing bolted to the block and the trans connected to the bellhousing.
Jeff Joyce
Binder Driver
Jun 24, 2003
732
Raleigh, NC
So does the 545 have a typical integral bellhousing with a round SAE pattern? If so, it should look like this ...
http://www.industrialautomatic.com/html/at545.htm
From what I've been reading, for a medium duty 7.3/545 IH app, there are essentially two peices. One is the flywheel housing (7.3 to SAE) and includes the starter, the other is the transmission.
Can you snap a photo?
CareyWeber
Staff member
Moderator
3,814
Ridgeway, SC
Bingo if it's SAE # XYZ then it has two pieces the adapter from the engine to SAE that is the flywheel housing and then there it the transmission adapter to SAE # XYZ.
Bolted together in this order.
Engine Block - Flywheel Housing - Transmission adapter - Transmission
Carey
Jeff Joyce
Binder Driver
Jun 24, 2003
732
Raleigh, NC
So, is there an IH-T3x to SAE #2 or #3 bellhousing out there? If so, I'd love to have one.
If not, does the IH-T3x bolt to the same Spicer 3x5x SAE bellhousings? Like the ones from military apps?
I've heard that the 6.9/7.3 block is "similar" to the MV series gas V8s. If so, is there an MV to T-3x bellhousing that would go directly between the 7.3 and T-36? Ken (IHWillys) seems to think so.
If non of the options above are available, I'd go with a complete manual setup from an S series, including ...
- 7.3 to SAE flywheel housing & flywheel
- Spicer 3152A or Clark 267V (close ratio direct 5th) with matching bell housing and SAE adapter
- all the appropriate clutch parts
Anyone have one of these combos laying around???
WRENCH MAN
Dreams of Cub Cadets
Dec 24, 2004
4,425
Eugene Orygun
Eric VanBuren
May 7, 2004
6,011
Maple Valley , Wa
Yeah I can snap a couple of photos but I am not going to be a work until Wed and those rigs won't necessarily be at my disposa,l since they are IH's we usually only see them for oil changes. We also have a F53 that has a hack job Allison install to replace it's E4OD, but again I don't see it that offten, most of my day is spent with the Chev/GMC P30s.
Jeff Joyce
Binder Driver
Jun 24, 2003
732
Raleigh, NC
I havent confirmed that this will fit my T36 but it is an SAE #2
It has the 6 hole pattern that's consistent with the T-36. Here's an SV bell with a T-36 ... looks the same as yours except it's not SAE and doesn't have the starter bump.
http://www.binderplanet.com/forums/showthread.php?t=87096
The Spicer 3152 to SV bell I have looks the same as the T-36 bell, but the 2 lower holes are blank (i.e. filled). In case anyone cares, the T-36 bell shown above was connected to a flywheel housing on a 354 Perkins. I think it was an original IH application Perkins, probably from a Loadstar.
Wrenchman, would you like to sell that SAE bellhousing??? If not, where could I find one? i.e. in what application?
WRENCH MAN
Dec 24, 2004
4,425
Eugene Orygun
My T-36 has the common bellhousing shown in the link/other thread, it came from a Loadstar.
NO, I don't want to sell it, I may need it if I ever get a diesel!, I got this one from a pile of bellhousings at a truck wrecking yard so I really have no idea what it came from?
CareyWeber
Staff member
Moderator
3,814
Ridgeway, SC
Eric VanBuren
May 7, 2004
6,011
Maple Valley , Wa
The 7.3 is based on the MV block 404, so if you found a 404 bellhousing you might be able to use it. I think SAE is a better way to go though.
The MV bellhousing mounting is the same as the "T" since the engines were designed together with common front and rear interfaces, mountings ect, to require a minimum of unique parts. Even the water pump is the same in IH applications. So unless you get really lucky finding one on a T will be many times more likely than the way less common MV.
Jeff, sorry I haven't got a pic yet of a factory IH to Allison set up yet, but as expected I was busy fixing Chevys. The only IH that needed service this week was DT powered, and the only reason it was in because the idiot driver broke the TS lever clean off somehow.
Hopefully next week a "T" powered IH, or better yet the Allison converted Ford, will be due for a LOF. Or the Chevys won't break so much, I know keep dreaming, and I'll have the time to go tilt the hood on one of the "T" powered spares.
Jeff Joyce
Binder Driver
Jun 24, 2003
732
Raleigh, NC
I assume T = 6.9 or 7.3.
I'd heard the MV bell housing may be a solution to this. As you've noted I also hear these are rare. So, If I found an MV bell, wouldn't I also need a starter and flywheel for that application to make this work? Are the MV and T flywheels the same?
Eric, are you saying that some early Ts may have an MV bell housing? Do you know what years? Would this be mated to the later model T-495 or T-496?
Sorry for all the questions, this kinda info just isn't readily available online.
Carey - Thanks for the pics. Do you know what transmission they used there? I thought the ZF had an integral bell housing. So, maybe a T-19?
stu simpson
High Wheeler
Dec 15, 2004
1,953
portsmouth, nh
Eric, are you saying that some early Ts may have a one piece bell housing on them, same as the MVs did? Do you know what years? Would this be mated to the later model T-3x, known as T-43x?
I am now convinced you should ditch all that other stuff for a Spicer 6-plus from behind a T444E from a 4700. It would bolt right up to a 6.9/7.3 and give you a good granny and OD. I would seriously consider buying that T36 from you if you did it for my 1510. If not maybe I'll go that route eventually in the Travelall with the 7.3 from my van...the ZF is a good idea too. I think you might be chasin' ghosts here.
Jeff Joyce
Binder Driver
Jun 24, 2003
732
Raleigh, NC
7 gears, bring it on! I'm sure that a Spicer 6+1 is going to be pricey, likely considerably more than a running 7.3. Let me know if you see any available.
I'm not set on any particular transmission, but I'd like to use what I've got if I can. The T-36 is in place and working. Anything else will likely require driveshaft mods, which can get expensive.
I'll have some time to locate my engine-trans interface parts while I take care of some body work. Plenty of time to chase ghosts ;)
I also looked at what it takes to use my Spicer 3152 behind a cummins, ~$1000 in housings, adapters, flywheel before I even get the engine or a starter.
Eric VanBuren
May 7, 2004
6,011
Maple Valley , Wa
Yes by the "T" series engines I mean those also known as the 6.9, 420, 421, 7.3I, 444, 445, depending on if it was originally installed in a IH or Ford chassis.
For some reason IH rounded the CI down while Ford rounded it up which is a change since the SV we know as a 392 is actually a 391 which is reflected on some intake gaskets, when you follow the standard mathematical convention of rounding. The "392" actually displaces 391.47 IIRC cubic inches.
Back to your question I don't know if the flywheels interchange between the MV and T, my gut instinct, based on the other parts interchangeability says yes, and it will almost certainly bolt on, but I don't know if the balance is the same.
Here is a shot from the IH service manual showing the rt rear of an MV engine with the SAE bellhousing attached, from my recolection it is at least similar to that used on IH app "T", note that it is much deeper than the 460 pattern unit and includes the side mount bosses as well as the starter mount which does take MD industry standard Delco MT series starter.
http://www.tpub.com/content/firetru...210-230-14P-1/css/TM-5-4210-230-14P-1_633.htm
http://www.tpub.com/content/firetru...210-230-14P-1/css/TM-5-4210-230-14P-1_650.htm
http://www.tpub.com/content/firetru...210-230-14P-1/css/TM-5-4210-230-14P-1_651.htm
and the first page of the MV manual
http://www.tpub.com/content/firetru...210-230-14P-1/css/TM-5-4210-230-14P-1_630.htm
If you peruse the manual further you will note a number of interchangable parts between the MV and the T engines
You will also find that many of the gaskets are the same including the rear main seal set, oil pan
