mallen
Lives in an IH Dealership
Freight defense part number 100013 for Kenworth trucks fits. The set contains a ignition cylinder and two door cylinders. The door cylinders are identical to the originals, the ignition cylinder is similar, and close enough to work. It's missing one of two little protrusions on the back, but that does not affect it's operation.
This one shows the original ignition lock cylinder. Notice the extra cylindrical protrusion. It's missing on the middle cylinder above but does not seem to be needed. It looks like you need one or the other but not both.
To replace the door lock cylinders:
Open the door and remove the inner panel. There is a clip on the edge that retains the lock. Remove the clip and slide the lock out.
If you have the key, place the key in the lock. This retracts the tumblers.
With the key in the lock, retract the clip using a sharp pick as shown. Then press on the shaft and the cylinder should slide out of the lock.
If you don't have the key, use the pick to retract the clip.The procedure is the same but as the lock cylinder slides out of the housing, the tumblers may catch. The original cylinder did this bit the new one did not. There is a hole in the side of the lock right before the front bezel. If it catches use the pick to retract the tumblers one by one as you slide the lock out lock from the cylinder.
To reassemble, put the new key in the new cylinder, place the lock cylinder on the shaft and slide it back in. Turn the lock so that the tumblers line up with the notch and remove the key. Your door lock is now rekeyed.
To rekey the ignition lock, use the following procedure.
Place the key in the lock. There is a hole where you put a paperclip or a pick. Turn the lock counter clockwise to the accessory position, you should be able to see clip that holds the cylinder in place. Depress it and slide the cylinder out.
The clip can be seen in the right-hand side of the hole. In the second picture the pick is depressing the clip.
To replace the cylinder put the key in the cylinder. You may need to depress the clip. Then slide the cylinder back into the lock and rotate it until it locks into place.
