This conversion is very simple to perform. I started this when I had my first "Gold Box" go bad. I wanted a system a little more avail in the local parts store. I have made several changes over the years to the original conversion and for the non-FI crowd, there is even an easier system to use with this distr conversion.
Here's a little video to show how the system works. This is one for a carb and I used the electronic ignition round coil with .7 ohms resistance.
This conversion can save you over $500 when compared to the large cap HEI distributors being sold for the IH. This just happens to be the DIY/poor mans version but it works the same and uses the same ignition module.
Duraspark conversion video
Before you run to the junkyard, read this post to decide on ignition parts!!!
The preferred ignition is the GM 4 pin module for carbs and the GM 8 pin module for EFI
CLICK
The first thing you need for this conversion is the right IH distr.
I have only done this on the Holley distributors. They can be points or GB, and can be 4 or 8 cyl.
For FI conversion only
For non-FI conversion
For both- normal
Then you will need a couple parts from a donor Ford Duraspark dist.
There are 3 things you need.
1. The base plate. Used from a junkyard. Normally $5.
2. The reluctor. (I buy new)
Part Number: EL205
For Your Vehicle
Vehicle: 1979 FORD F-150 PICKUP
Engine: V8 5.8 Liter 2BBL
351M Eng.; 351W Eng.
Our Price: $3.97
3. The magnetic pick up. (I buy new)
Part Number: EL307
For Your Vehicle
Pick-up: 351M/W
Our Price: $19.48
Or Part Number...Wells parts were a little cheaper and are supposed to be pretty good quality.
Since I have not found a part number for the Base plate, I go to the local junk yard. While I am there I try to pick up a couple just in case some other binder nut wants to do the conversion also.
This is what the Ford Duraspark distr looks like.
To get to this, you just pop the clips off the cap and set it aside,
then pull the rotor off the center.
Now to get to the base plate you have to remove the reluctor. and vacuum advance. Just remove the 2 screws on the advance and the small clip that holds the arm on the base plate(if it has one).
Just use a couple of large screwdrivers and carefully pry up on the center from the bottom. Do not pry on the the fins!!!
Now just remove the 2 phillips screws and lift the plate out.
This is what it looks like.
Now to replace the pick up module.
Just remove the small snapring in the center and lift it off.
(Up to this point is what I do while at the junk yard. That way I only pay for the part I need.!!!)
Back at home..........
Grab either your points distr or your Gold box distr and remove the 2 screws holding the vacuum advance on and the clip on the arm. Once off, then remove the 2 screws holding the plate in the distr.
Here's what the bare holley plates look like.
Note the mounting holes are slots.
Now set the old plate on top of the Duraspark(DS) plate and line up one of the slots with a mounting hole in the DS plate.
The other one won't line up.
What I do is just grab my cut off wheel and make a new slot in the DS plate to match the Holley mounting slots.
You can also just mark it and use a drill.
NOTE the difference in the size of the center holes in the plate!!!
Here's how it looks in the distr. (you won't be able to do this yet) But note how close the shaft runs inside the new DS plate!!
CLICK
For both- normal
Part Number: EL205
For Your Vehicle
Our Price: $3.97
Part Number: EL307
For Your Vehicle
Pick-up: 351M/W
Our Price: $19.48
