Do you use lead substitute in a 74 Scout II?
eyeluv2fish
Mar 29, 2004
7
Fresno, CA
I just picked up a 74 Scout II with a 345. When I pulled into the gas station the other day it occured to me that I might should use leaded gas. I checked the owners manual and it clearly says use leaded gas. However, I asked a couple of binder buddies about it and they say it doesn't matter as long as you use high octane gas.
To lead or not to lead...that is the question... :confused:
SCscoutguy
Moderator
Staff member
Moderator
Jul 25, 2004
5,281
Florence, South Carolina
Your engine has hardened valve seats in it so the unleaded gas wont hurt it. As far as the hight octane stuff I dont see any reason for running it. The SV engines were made to work not to be hot rod's. I have run just regular 87 octane for years in my trucks and they run fine. Semper Fi, John
Munchies
High Wheeler
Oct 19, 2003
1,462
Heidelberg, Germany
No reason to use lead. No reason to use octane booster. The octane booster will usually hurt your performance unless your pining, (high compression, turbos/supercharger) and IH SV engines are about as low compression as they come.
