eyeluv2fish
I have always charged my own A/C on my newer model cars. I have also done several conversions from R-12 to R-134A with nu hiccups...
Need help from someone with experience converting Scout A/C.
First - I need to figure out which is the low pressure side. I know that usually the low side is the one with the larger hose that gets cold when in operation. However, I bought one of those retrofit kits from Walmart (with the nipples and the R-134A/Oil Combination cannisters). I used it to charged what I thought was the low pressure side (the nipple on top) but it only took about 1/2 can before it read 60+ pounds and it still doesn't blow cold. Also, my compressor will go for several minutes sometimes before it kicks in. Then it may only run 3 seconds or less before the clutch disengages again. When this happens the blower on the inside also cuts out.
Did I charge the wrong side. Am I going to have problems using one of these retrofit kits or should I take it to a mechanic?
Any help is appreciated
