Cannister Oil Filter leak on a 1963 Scout
Rogerhh
Feb 15, 2020
47
Hye, Texas
How do you keep the 1963 Scout Canister Oil Filter from leaking ... ?? When I order a filter I get a 1 narrow rubber gasket and 1 little wider rubber gasket with the filter.. they are essentially the same diameter.. I put both gaskets in but it leaks on three attempts ...
Dana Strong
Lives in an IH Dealership
6,261
Cannister Oil Filter leak on a 1942 Scout
How do you keep the 1942 Scout Canister Oil Filter from leaking ..
I once owned a 1961 Model 80 Scout that I understood was from the first year Scouts were made. Something about your question seems odd...
And I don't have a FSM or Parts book for the earlier Scouts, so couldn't look up the canister and related parts, even if I assumed you meant 1962, but would suggest your editing the title and text so that someone else might try to give a definitive answer. Pictures are always good for demonstrating exactly what you have (what is leaking where), but...
If I had to guess (my memory isn't good enough to recall such details from 50 years ago), I'd say there should be a gasket on top of the filter body sealing either the inlet or outlet hole where it seats against the base; perhaps a spring between the filter bottom and the canister, and a seal in a groove where the canister mouth mounts to the filter base. A copper washer-like seal under the holding-bolt's head, too?
Randall Barringer
Y-Block King
Mar 4, 2004
3,808
baton rouge, louisiana
I´ve only used one gasket on my straight 6 in the Travelall and the 4 in the Scout 80.
Take off the canister, clean everything, and place the gasket which fits best into the channel of the canister base. One of them should fit better than the other.
This all will work better if you use a strong light to be able to see what you are doing.
Place the canister on the gasket and make sure it is centered all the way around.
Once it is good, tighten it down.
I understand your frustration. On my last oil change in the Travelall, it took me many attempts to get it right.
Rogerhh
Feb 15, 2020
47
Hye, Texas
Really really appreciate the response. Would a little grease to the o ring make it stay in place better? I don't have a lift.
Yeah... the 'ole slip of the digit..
stroker3
Feb 5, 2009
6,251
Mass.
As Randall said, one gasket should fit better. It should stay put in the groove. Are you sure the old gasket is out? Might be worth a check. If you can't see, an awl will help by feel. It can be tough to hold everything in place perfectly as you're starting the bolt but one other thing that helps is to turn the canister back and forth slightly now and then as it being tightened and the canister starts to make contact with the housing. It helps to ensure that it's setting in the groove evenly.
George Womack
Y-Block King
Oct 13, 2001
3,241
Terlingua, TX
^This. If the old gasket has been in there a long time, it will be very hard and can look like it's part of the metal. And yes, only one gasket, the one that fits better.
Oh, and The Machine Shop is a sub-forum, and Anything Scout is the name of a business. Your posts will get more attention if posted in General IH Tech.
Rogerhh
Feb 15, 2020
47
Hye, Texas
Really appreciate the info. The little skinny one fits in the grove and that's the ticket. The fat gasket that is in the pack is just an option..
