Cage Legs
Anything Scout
May 21, 2013
12
Ames, Iowa
We all want a roll-worthy cage but no one wants an intrusive bar running down in front of the dash blocking the headlight switch, window crank, and e-brake pedal. Our new cage legs are the cure to this problem. We've taken the concept that has been out there for quite some time and added some finesse and styling that will make your cage look trick. Engineered from 5/16" steel plate these legs are designed to fit snug but secure right along your dash, giving you the strength you need and the interior space you deserve. Our cage legs fortify the existing strength of the door pillars and body mounts and create a clean, safe cabin for your piece of mind. We also build cages locally and offer many cage accessories and building supplies.
customtronic
Nov 15, 2011
455
Olympia, WA
Great idea! Is this something that can be added to an existing cage or does it integrate to your frame only?
Anything Scout
May 21, 2013
12
Ames, Iowa
Thank you! Great question! Our cage legs can be fairly easily made to work with an existing cage. It may require cutting your old cage back a ways in order to direct the tubing at the correct angle to hit the top plates of the legs but this will give you an opportunity to use some sweet products that are on the market. We use "id tube clamps" when we need to connect tubing together. We can get them for you ($35ea.). They are very strong and they look trick. They will also make it easier to remove the front part of your cage if you ever need to service your dash.
