Here are shots of the Blue Diamond engines, feel free to share your pics of this engine family in this thread, along with any information you wish to share.
Below is a cross section view of the Blue Diamond engine, also known as the "FAB" engine. ?Cubic inch ratings that I know of are 262, 269, 282, and 308.
Here are shots of a recent overhaul by one of our folks:
Notice the tall distributor shaft that begins at the bottom of the block and travels all the way up to the valve cover before terminating in a Delco-Remy mechanical advance distributor. Also note the early "Marvel" style sock-type oil filter. To my knowledge, the Blue Diamond engines never got a full-flow canister filter.
Here is a passenger side view of the engine:
Note the extremely thick and heavy intake/exhaust manifold, and the fine quality casting in comparison to the Silver and Black Diamond engine manifolds which are notorious for cracking and burning out. The Blue Diamond engines have superior castings and much stronger and heavier components based on visual inspection alone.
It should also be noted that I have never found any Blue Diamond engine with anything other than a 1bbl carburetor. I have also been witness to 3 different units installed on the engine, manufactured by Stromberg, Carter, and Holley.
More pics as I find them, and more information as it becomes available.
Keep on Binderin',
John
