Jack H
Hey all, I've been lurking on this thread for a while, but finally decided to share some of my build that I'm working on currently. This is the third scout I've owned. The first vehicle I ever purchased was a 1975 scout 2 which I owned throughout high school, my second was a 69 800A with a 4 banger. I sold the 69 about 7 years ago after moving to southern California. Well, a little over a year ago I convinced my wife to let my buy another....In comes the green machine. I'm now wrenching on a '70 800A, 304, 4sp, originally from Arizona truck. Being from Arizona, it had a little more rust than I would have liked, but all repairable. The truck I purchased was drivable, and the motor ran great, shifting was a little difficult though. Anyways, my plans were for a resto-mod-ish build. I wanted a weekend trail truck that can also take me to work and back. Anyways, here's some of the things I've done or plan to do:
-Sand/Paint the frame - Done
-New bed (In progress) - Done
-New passenger/driver floors (done)
-Rust repair behind doors, and rear wheel wells (done)
-Gas tank in between the frame with a fuel door (done)
-Rebuilt transmission, transfer case, new clutch, TO/Pilot bearings, new rear main seal, oil pan gasket (Done)
-Rebuilt the rear axle D44 (done)
-Purchased, regeared and rebuild a D44 front axle from a scout 2 and installed (Done)
-Rebuilt Heater box/core (Done)
-Remove body panels and paint behind (Done)
-Install Scout 2 Power steering box/pump and borgeson steering u-joints, new steering column wiring/turn switch - Done
-Add 10SI alternator (Done)
-Rewire the whole truck with new gauges (Done)
-Hydroboost brake install (Done)
-Body work/paint (Not started)
-Fabricate new front winch bumper. - Not started
-Fabricate Rock sliders - Not started
-R&R Radiator, new thermostat and hoses - Done
-Bedliner for the floors - Not Started
-Fab rear tire carrier/jerry can holder - Not started
R&R Tailgate and doors - In progress
Here's the truck as I got it
Rear axle with gas tank
Some minor body work and fuel door addition
New floors
Patch/metal work in the rear wheel wells
Front Axle
Nifty firewall grommet/plugs I made to cover the holes where the BHC's were.
Painting stuff. The scout will be red with a white top.
Anyways, this is just a preview. I have been taking pictures of everything and I have had pretty much this whole scout apart at one point in time. So, if anyone needs any pictures of anything or info, I'll help if I can. Or if you want more details on anything, hit me up! I'm installing the MAD electrical kit right now and a new kwikwire harness with new gauges right now. After this, I'll be doing the hydroboost, so I'm sure I'll have some questions down the road.
Thanks for viewing!
Jack
Front Axle
Thanks for viewing!
Jack
