FWIW, those bump-stops I have on the front are Energy Suspension stops. Height is 2.5". The next size up from the ones I have, in that center-bolt style, is 4.5". I don't want that much stoppage. And to be honest, I don't like that the urethane block is pealing back from the steel plate. Might be caused by where and at what angle the axle hits them; not sure.
The most practical option for me would be to pull off those E.S. stops and mount these 3.5" Prothane stops, which are the same type as I'm using on the rear end. Looks like I could still use the center-bolt mounting. If necessary, I'd just cut off those tabs on the ends. Or weld on a steel plate to accommodate the outer bolts, if it'll fit and not interfere with the shocks:
https://www.prothanesuspensionparts.com/191309
