Resource icon
Interpreting Lineset Component Codes
Here is Version 1.0 of the IH Component Code/Vendor Code listing that I have compiled from various sources, including considerable help from Kurt Musgrave and Allen Weidenheimer, who have IH Sales Data Books that break some of this out. It is not complete; input from anyone having a pre-1960 Travelall/Pickup and a lineset will be appreciated. Codes for K-series and possibly L-series trucks are not included, as these used a totally different set of 4 digit codes before the current system started sometime in the 1950's.Howard Pletcher
Howteron Products, Inc.
Front Axles
02001 IH F-165 I-Beam 2800#-1100
02003 Dana Tubular 3200#-Scout II 4x2
02004 Clark 2000 # I-Beam for 4x2 Scout 80/800
02005 IH Coil Spring IFS 3200#-100 Series
02006 IH Coil Spring IFS 3500#-200 Series
02007 IH Coil Spring IFS 4000#-200 Series
02008 IH Torsion Bar IFS 2800# less sway bar-1000 Series P/U
02009 IH Torsion Bar IFS 2800# w/ sway bar-1000 Series T/A
02010 IH F-170 I-Beam 2700#-C-120
02011 Dana 30 Driving w/27 ends-2500#-Scout 800
02012 IH I Beam 3800#-1200, 1300
02013 Dana 30 Driving 3100# Open ends-Scout II
02014 Dana 27-Driving 2000#-Scout 80/800
02015 Dana 44 Driving 1200-4x4
02016 Dana 44 Driving 2800#-1100-4x4
02017 Dana 44 Driving 2800# w/Power-Lok
02018 Dana 60? Driving 3500#-C-120
02019 Dana 60? Driving 3500# w/Power-Lok
02021 Dana 30 Driving 2500# w/PwrLok-Scout 800
02024 Dana 27 Driving 2500# w/PwrLok-Scout 80/800
02025 Dana 44HD Driving 3500#-1200 Series
02028 IH I Beam 4000#-1510
02044 Dana 44 Driving 3200# Open ends-Scout II
02045 Dana 44 Open End Driving 3000#-1200
02046 Dana 44 Open End Driving 3000#-1100
02051 Dana 70 Driving 6000#
02052 Dana 70 Driving 6000#--1300 Series
02062 Dana 44? Driving 3400#-100 Series
02063 Dana ??? Driving 3500#-200 Series
Steering Gears
05003 Ross TL-52 Manual Steering-C-110
05008 Gemmer 24J Manual steering gear-Scout II, Scout 800A/B w/6 & V-8, 68 LL
05009 Gemmer 24D Manual Gear-1967 Light Line
05012 ??? Manual Gear-Scout 800
05014 Ross SL-52 Manual Gear, Scout 80, C-100
05019 Ross HPS-52 Power Steering, C-100
05165 Gemmer 378 Manual steering gear, 1310 4x4, 1510
05281 Saginaw 700D Power Steering-Scout II, Light Line
05282 Saginaw 708D Power Steering-Light Line
Clutches
11103 Dana? 10" 6-spring-Scout 80 (4-152)
11107 Dana 10", Scout w/4-196; 1320 lb
11095 Rockford 10-1/2", Scout, 1010-1510 w/6-232; 1570 lb (Belleville spring)
11118 Rockford 11", 1010-1510 w/V-304, 345; 1850 lb
11123 12", 12-spring clutch
11215 Dana 11" (Angle link) Scout w/V-304; 1800 lb
11216 Dana 11", (HD angle link) Scout, 1010-1510 w/V-304, 345, 392; 2000#
Engines
12001 BD-220 Gas
12002 BD-220 LPG
12005 BD-240 Gas-Canada
12006 AMC 6-232
12010 BD-240, BG-241 Gas
12011 BD-240, BG-241 LPG
12012 BD-264, BG-265 Gas
12013 BD-264, BG-265 LPG
12015 BD-264 Gas-Canada
12016 AMC 6-258
12020 BD-269 Gas
12021 BD-269 Updraft-Gas
12030 BD-282 Gas
12031 BD-282 LPG
12090 IH V-266
12091 IH V-266 LPG
12095 IH 4-152
12096 IH 4-152T Turbocharged
12098 IH V-304A, Export & Canada, 79, 80
12099 IH V-304A, All years US, Export & Canada pre-79.
12100 IH V-304 Low Compression-Export
12101 IH V-304 LPG
12102 IH V-304
12107 IH V-345A w/2 barrel, Export & Canada, 79-80
12108 IH V-345A w/4 barrel, 74-78
12109 IH V-345A w/2 barrel, 74-78
12110 IH V-345 Gas
12111 IH V345 LPG
12112 IH V-345
12114 IH V-345 w/4 barrel Thermo-Quad, 79-80
12115 IH 4-196 Low Compression-Export
12116 IH 4-196 All years US, Export & Canada pre-79
12117 IH 4-196 Export & Canada, 79-80
12120 IH V-392
12121 IH V-392 LPG
12122 IH V-392 w/ 4-barrel Thermo-Quad, Increased Cooling
12128 AMC V-400 (not to be confused w/IH LV-401 series)
12211 Nissan SD-33
12212 Nissan SD-33T
Transmissions
13001 IH? HNS 3 speed-1961 Light Line
13002 IH? HNS w/Overdrive-1961 Light Line
13003 IH? CHDA 3 speed
13004 IH? HWS 3 speed col shift-C1100
13005 Warner Gear T-87D
13007 Warner Gear T-87E 3 speed floor shift-Light Line
13008 IH? HWS 4 speed w/OD
13010 Warner Gear T-9
13011 Warner Gear T-9 w/dual PTO
13013 Warner Gear T-90, 3 Speed, same as 13014, Scout 2WD
13014 Warner Gear T-90, 3 Speed, Scout 80, 800, and II thru '74 1=3.34, 2=1.85, 3=1.00, Rev=4.53 - 4x4
13015 Warner Gear T 98A 4 speed-Light Line
13016 Warner Gear T-98A 4 speed with LH PTO-Light Line
13017 NP-435 with right PTO-Light Line
13018 NP-435 with left PTO-Light Line
13019 NP-540 Dir in 5th
13020 IH? HP-875--repl by NP-540
13021 IH? HP-895--repl by NP-540, also shown as 4 speed for early 800's, probably revised to T-45-exact model unknown
13023 NP-541 Dir in 5th
13024 Warner Gear T-98 or IH Mfg? 3 spd column shift, Light Line
13026 Warner Gear AS2-5G Auto
13027 Warner Gear AS4-7F Auto-C-100
13028 Borg Warner Automatic--first auto in Scout 800, D-1000
13029 Omit Transmission Code
13034 IH 5 speed, OD, 6.21 low-Light Line
13035 IH 5 speed, Direct, 7.17 low-Light Line
13036 IH 5 speed Direct, 6.21 low-Light Line
13039 Borg Warner 11 Automatic w/11" conv., Scout 800 and II thru '71 w/ V-304 and smaller engines
13044 Warner Gear T-18, 2 WD., LH PTO same as 13045, shown as T-18C for Scout, T-18A for light line
13045 Warner Gear T-18C, 4 Spd, LH PTO-Scout 800 and II thru '75 1=4.02, 2=2.41, 3=1.41, 4=1.00, Rev=4.73
13049 Borg Warner 11 Automatic w/ 12" conv., Scout II w/V-345, 1971 only, Light Line w/ V-345 and 392.
13332 Warner Gear T-15D, 3 Speed, Synchro low, '75 and later Scout, earlier in LL, 1st=2.997, 2=1.55, 3= 1.00, Rev=2.997
13407 Chrysler A727 Automatic, '72 and later Low=2.45, D1=1.45, D2=1.00, Rev=2.20
13409 Borg Warner Model 11 Auto Transmission, 1972 1210
13418 Warner Gear T-18, 4 speed, wide, Right side PTO-13/1500, opt. 11/1200
13419 Warner Gear T-18, 4 speed, wide ratio, Left side PTO- 1300,opt 11/1200
13427 Warner Gear T-19, 4 Spd Wide Ratio, Synchro Low. '75 & on. 1=6.32, 2=3.09, 3=1.68, 4=1.00, Rev=6.96
13428 Warner Gear T-19A, 4 Spd Close Ratio Synchro Low, '75 & on. 1=4.02, 2=2.41, 3=1.41, 4=1.00, Rev=4.42
13434 IH 5 speed, OD, 6.21 low-Light Line-intended as replacement for T-34/5/6
13435 IH 5 speed, Direct, 7.17 low-Light Line "
13436 IH 5 speed Direct, 6.21 low-Light Line "
13445 Warner Gear T-18A, Close ratio. Same as 13045 except PTO on Rt side and not setup for t-case. Opt Light Line
13494 IH 5 speed, OD, 6.21 low-Light Line--replaced T-434/5/6 in 1974.
13495 IH 5 speed, Direct, 7.17 low-Light Line "
13496 IH 5 speed, Direct, 6.21 low-Light Line "
Transfer Cases
13140 New Process
13141 New Process 202 single-lever, 1.96 low, C-120
13142 New Process 205 1.96 low-Light Line.
13143 IH Chain Drive Transfer Case-Single Speed, Scout II
13144 Dana Model 18, 2.46 low-Scout 80
13145 Dana Model 20, 2.03 low-Scout 800 and II
13146 Dana Model 300, 2.62 low-1980 Scout II
Rear Axles
14001 Dana 44 3300#-C-100
14002 Dana 23
14003 Dana 3300# w/Power-Lok-C-100
14004 Dana 27 2300#-Scout 80/800
14005 IH R-1060 3300#-C110
14006 IH R-1060 3300# w/Power-Lok-C110
14007 Dana 44
14008 Dana 44 w/Power-Lok
14009 Dana 44 3500# w/tapered shafts-Scout 800, C100
14010 IH R-1070 4500#-C120
14011 IH R-1070 4500# w/Power-Lok-C-120
14012 Dana 27 2000#-Metro
14013 Dana 27 2000# w/Power-Lok
14014 Dana 27 2300# w/PwrLok Scout 80/800
14015 IH R-1165, 55007500#-1300 series
14016 Dana 60 5000-5500# full floating-1200, 200 Series
14017 Dana 60 5000-5500# w/Trac-Loc-full floating-1200, 200 Series
14018 Dana 44 3500# Scout 800A thru Scout II, LL
14019 Dana 44 Wide Tread 3500#
14020 IH R-1170 10,000# or 12,000#-1500
14021 Dana 23-Metro
14023 Dana 44 3500# w/PwrLok w/tapered shafts-Scout 800
14024 Dana 44 Wide Tread 3500# w/Power-Lok
14025 IH R-1440 12,000#-500 Series
14028 Dana 44 3500# w/PwrLok (pre-1970)/Trac-Lok-Scout 800A & II, Light Line
14053 Dana 60-2 3700# semi floating-1967 Light Line
14054 Dana 60-2 3700# semi floating w/Power-Lok-1967 Light Line
14063 Dana 70 7500# w/Power-Lok-1310, 200-earlier may have been IH R-2682
14083 Dana 60 3800# semi-floating-1100, 100 Series
14084 Dana 60 3800# semi-floating w/Trac-Lok-1100, 100 Series
14126 Eaton 13802 13,500# 2 speed-1500
14184 Eaton 15201 12,000# 2 speed-1500
Notes:
Items marked with a ? are best guesses that we could not verify.
Weight ratings shown are typical, but vary from year to year.
Models shown are intended to be a guide to when and where the component was used, but are not intended to be a complete list of all models using the component.
Components included are only those available in Scout and Light Line vehicles, although some components like New Process 5 speeds were included even though they were not regular options, but were used for some orders.
Howard Pletcher
Author
Howard Pletcher
Views
368
First release
Last update
Rating
5.00 star(s) 2 ratings
Latest reviews
Great info!
