FA-5 Front Axle Parts
1. Lower ball joints aren't made anymore. I scored some on eBay. That's your best route. Moog K-3101 / TRW 10276. (Unique 74/75 only part)
2. Upper ball joints are readily available. Moog K-778.
3. Steering ends are tricky as well. Rock Auto did have the outers recently. Moog ES-2022RL. Inners are tough to find now. Moog ES-2021RL. Adjusting sleeve Moog ES-500S. (Unique 74/75 only part, excluding the adjusting sleeve)
4. Lower control arm bushing is a unicorn. IH part number is 443322C1. Allegedly, Rare Parts info is "RP16694, 16694-2I47A, Control Arm Bushing" (Unique 74/75 only part)
5. Upper control arm bushings are readily available I believe. I think it's Moog K-7104.
6. Wheel bearings are Timken SET16 and SET17.
7. Seal is National 40389S. (Unique 74/75 only part....I think)
8. Brake rotor hub assembly? Forget it. That's a real tricky one. IH part number is 442225C91. (Unique 74/75 only part)
9. Rubber brake lines RAYBESTOS BH381190 (Unique 74/75 only part)
10. Steering center link.....haven't seen one. IH part number is 442917C91. (Unique 74/75 only part)
11. Stabilizer bar bushings IH part number 158759R1. These can be found NOS pretty easily. Scout Connection has these.
