By Mike Toney (MikeInMobile,AL)
Part SOURCES here.
Here are the current part numbers that I have for the IH 1961 to 1973, 100, 1000, 1010 2wd FA8, FA9, torsion bar IFS steering, suspension and brakes.
Idler arm,
69-73 FA8/9, www.rareparts.com #20237* , MOOG K-3086
67-68 FA8/9, www.rareparts.com #20235*, MOOG K-3081, NAPA (Perfect Circle) 268-3516, McQuay Norris 1FA462
61-66 FA8/9, MOOG K-3027
Centerlink,
69-73 FA8/9, www.rareparts.com #27293*, www.scoutconnection.com , #?
61-68 FA8/9, www.rareparts.com #28191*, www.scoutconnection.com, #863658R91
Inner tie rod end,
69-73 FA8/9 driver side, MOOG ES402RL
67-68 FA8/9 both sides, www.rareparts.com #25516*, www.scoutconnection.com #351845C91, MOOG ES400R
61-66 FA8/9 both sides, www.scoutconnection.com , #?
Outer tie rod end,
69-73 FA8/9 pass side, MOOG ES354R
69-73 FA8/9 driver side, MOOG ES354R, adjusting sleeve, MOOG ES500S
67-68 FA8/9 both sides, www.rareparts.com #25515*, www.superscoutspecialists.com #330527C91, MOOG ES400L
61-66 FA8/9, www.scoutconnection.com , #?
Disc brake calipers,
69-73 FA8/9, RWC5106/RWC5107 unloaded, RC4061/RC4062 loaded
Disc brake pads,
69-73 FA8/9, Carquest RD 185, Raybestos RRD39
Disc brake hoses ,
69-73 FA8/9, NAPA UP381205, Raybestos BH381205, Carquest SP5297
Disc brake wheel bearings,
69-73 FA8/9 front disc inner bearing/race, Carquest A3
69-73 FA8/9 front disc outer bearing/race, Carquest A5
69-73 FA8/9 front disc inner hub seal, 203006
Shocks**
61-73 FA8/9, (Front shocks) Gabriel 82049, KYB 1923137
Ball joints**,
61-73, FA8/9 Upper, www.rareparts.com #10391*, MOOG K-3084, TRW 10150N
61-73, FA8/9 Lower, www.rareparts.com #10392*, MOOG K-3085, TRW 10151N
Strut rod bushing kit**,
61-73 FA8/9, NAPA NCP2749014,
Advanced Auto Parts (www.partsamerica.com) FA7081 $6.79,
2 kits (4 bushings) required per vehicle., MOOG K-3060A w/2 bushings
Control arm bushings** ,
61-73 FA8/9 Front upper arm, FB610, Advanced Auto Parts (www.partsamerica.com) $7.99, NAPA NCP2671122, 2 bushings required per vehicle, MOOG K-3046 upper arm kit w/2 bushings
61-73 FA8/9 Rear upper and lower arm bushing%,
AC Delco 45G9003 (www.rockauto.com) $11.43 ea, NAPA NCP2673174, 4 bushings required per vehicle, 2 upper rear, 2 lower, MOOG K-3047 lower bushing
%(FB 630 is also listed for this application, but N/A currently)
*(Also available online and in store from www.autozone.com and www.partsamerica.com under the rareparts.com part number. This info is current when using part number searches on both sites as of 12/20/06)
**(Note, these parts fit ALL disc and drum brake 61 to 73 IH pickup trucks/Travelalls with the FA8/FA9 IFS front suspension)
Moog, TRW, Mcqay Norris, Gabriel, and IH part numbers are listed for reference only since they are no longer manufactured for these applications, though NOS parts do continue to surface and become available. These obsolete numbers are useful when looking at NOS parts with manufacturer numbers attached or printed on a box containing the part. Visual confirmation should be made prior to purchase that the part, especially if inside a box, is the correct part for your application, regardless of the number on the box.
(Part numbers updated 2/08/09)
Part SOURCES here.
Idler arm,
Centerlink,
Inner tie rod end,
Outer tie rod end,
Disc brake pads,
Disc brake hoses ,
Shocks**
Ball joints**,
