Go Back   Binder Planet Forums > Special Interest Groups > Restoration Purists
Old 01-26-2011, 04:22 PM
Buzzard's Avatar
Buzzard Buzzard is offline
Default '65 Scout 80 resurrection
I've had this thing for 10 years, bought it when I was 15 as a first car drove it like 10 miles then spun a bearing, and its been sitting every since. I intended on fixing it but came across a 67 800 with a v8 for cheap so I bought it and moved on. But I recently sold my Dakota and need something to wheel and throw my dirt bike in. I was going to just buy a little yota truck but decided this was the time to fix the scout or sell it, fix it won! I'm in the process of rebuilding my kx engine(bent a valve) as soon as its back together Im rolling the scout into the garage.
My plan is as follows:
Pull the crank and see if it needs to be turned or replaced
I'm really debating just getting a kit and pulling the whole engine apart just so I know its good to go.
replace the rear shackles/u-bolts and brake lines
inspect the leaf springs and get a rear drive shaft
(robbed that stuff for my 800 when the rear end fell out while I was driving but thats another story)
naturally change all fluids I need to check and flush the radiator
and figure out a keying situation I have none for it but that wont be to bad
I know there are some other things Im not thinking about but any advice and tips are appreciated. I'll update when I make some progress and pics!
Old 02-16-2011, 09:10 AM
Buzzard's Avatar
Default Re: '65 Scout 80 resurrection
Just an update, or lack there of. still getting the kawi put back together parts are trickling in for both projects should have some pics of the scout up sometime this week
Old 03-14-2011, 06:38 PM
Buzzard's Avatar
Got the scout home and mostly clean, rats had made a nice nest under the hood. I started pulling things off the engine to get it ready to be plucked. Any suggestions on a crank? Hopefully I can just replace the bearings or get it turned, but if not I havnt had much luck on finding one, havnt looked very hard though. Same with the rear shackles I'm sure its not going to be hard to find some for it, but whats the deal with the cj springs? i hear they are compatable and can give 2.5" of lift, is it worth it?
Old 03-17-2011, 11:17 AM
skookumchuck skookumchuck is offline
I am looking at a rebuild on a 1963 80 pickup. the motor is not turning over so I was considering putting in a diesel, so I am interested in how your build goes, good luck
Old 03-22-2011, 09:57 AM
Buzzard's Avatar
No?...
Old 03-29-2011, 05:06 PM
Alex Alex is offline
If you're going for a restoration why use Jeep parts?
Triangle lists the stock Scout springs, including heavy duty sets.
New springs, shackle bushings and body bushings will net you a pretty good lift on their own. The Scout will be at its stock height, which while it isn't hard core wheeler high, is the correct (restoration) height.
196 , 1963 , 800 , bearings , brake , clean , crank , deal , diesel , engine , hard to find , lift , parts , pickup , pulling , radiator , rear , rebuild , scout , scout 80 , springs , truck , wheel
Project - Get my dang Scout 80 back on the road! Mumpy General IH Tech 19 11-03-2010 11:08 AM
Scout 80/800 Serial Numbers rlireland BP IH Knowledge Wiki 0 10-27-2010 08:38 PM
Help with Scout 80 Clutch and T.O. Bearing Justin Graham General IH Tech 13 08-12-2007 04:48 PM
1985 CJ Leaf Springs on Scout 80? Finder-Binder General IH Tech 1 07-11-2003 11:06 AM
