I sure wish I had my Dad's first new truck. 65 C1100 step side w/3 on the tree! And his first Scout 75 Travel Top. If I was I missed it. Do you have a 266 or 304 or ????? Do you plan to keep the engine and drivertain? There was a guy at Nationals a few years ago with C1200 Travelette with axles, engine and 727 out of a early 90's Dodge with 6bt cummins. Very nice fit.
It's 3/4 inch black iron pipe from Home Depot (about $12). I cut the threads off one end. Then I measured the width of the tailgate, subtracted the length of the hinge inserts, and marked the pipe at that length. I sprayed POR metal ready in the hole for a day and then I pounded the pipe in with a 3# hammer (the end of the pipe deforms). It is a very tight fit, but it goes in slowly. After pounding it in most of the way, I trimmed the end at the mark I made previously. I then used a hinge (tapping with hammer) to get it the rest of the way in...
Andrew Duke 1966 Travelette (Retoration in process) 1966 Travelall (next restoration) |
Doors sand blasted and double powder coated with epoxy primer...
Responding to a couple of posts here...I tacked the pipe in place, but it didn't need it...not going anywhere...literally had to beat it in place (which removed dents from the lower rail of the tailgate.
Mark, The engine and drive train is fine and I'm keeping it as is. The engine was torn down and rebuilt about 20K miles ago and it had virtually no wear. The clutch, pressure plate, and throw-out bearing were redone then as well. I just rebuilt the rear, when I converted the truck to 4x4 using parts from a 66 Travelall.
Stripped down cab...I think I can put this thing back together later...
Looks good. |
I am loving this build and I WANT your truck!
Looking forward to seeing it come together.
67 1100B 2WD, 345, T-98 (Restoration in progress) Jonathan Gillespie Owner/Operator of a Carpet Cleaning business in Florence, AZ. |
What a wonderful heirloom!
I am enjoying watching the progress, I have a '66 Travelette that needs to be gone through and this is a very good lesson on how to go about it. Thanks for posting up.
Member - Gulf Coast Binders 1966 4x4 Travelette 1966 Stepside Pickup 1966 Scout 800 Sportop 1967 Scout 800 1970 Travelall - Project TraveLow 1971 Travelall 1974 4x4 Pickup 1976 Terra - Project First Degree 1977 Scout II - Project JPEater 1977 SSII |
Nice ride, looking forward to seeing it all painted. Great job on cutting down that bed! What are your plans for cowl repair? Be sure to post pics.
67 800 Limited GRC Edition, 266/T-19W/D300 79 Terra Rallye, mostly stock driver 61 Travelette, KOH Chase inspired build...........one day! 1250 Cub Quietline Last edited by gmbarker78; 06-29-2011 at 12:10 AM. |
| 110 , 1200 , 196 , 1966 , 2wd , 4x4 , axle , bed , brake , brakes , build , carb , fuel , fuel pump , number , part , project , rear , rear axle , rear brakes , roll , trailer , travelette , truck , wheels |
| 1966 Travelette on Craigslist | jlpdemag | Hill Country Binders - Central TX | 9 | 02-09-2012 11:12 AM |
