Old 12-13-2010, 01:25 PM
heff's Avatar
heff heff is offline
Default Changing factory gauges to aftermarket questions
I'm going to change my fuel, amps, and water temp gauges to aftermarket.
Going with a volt gauge instead of amps, a mech. temp, and a new fuel gauge. Already changed the oil to a mechanical.
What ohm rating will I need for the fuel gauge? Will I need to retain the CVR for this or no? I've read how to change the amp gauge over to a volt gauge so I think I have that covered. Any thing else I should be aware of?
Thanks
i like trucks.
Old 12-13-2010, 01:30 PM
Greyguild's Avatar
Greyguild Greyguild is offline
Default Re: Changing factory gauges to aftermarket questions
For fuel gauge : 10 Ohms = Full / 73 Ohms = Empty I think it's Chrysler that have those numbers also, could be wrong tho...
75 Scout II, 304 V8 automatic and a whole lot of rotten parts ...........RIP
My Build... Until it died
Only for an International
Nothing was fixable (Now I know)
aftermarket , amp gauge , chrysler , cvr , fuel , fuel gauge , gauges , hose , oil , question , water
Generic fuel sender and SW gauges questions ollie Triple Diamond Trucks 5 10-08-2009 03:12 PM
Factory fuel tank skid questions StanMcMurrey General IH Tech 4 02-13-2006 09:08 PM
Factory C series overdrive questions WesV General IH Tech 3 09-07-2004 02:49 PM
Factory Paint Questions Bruce Johnson General IH Tech 1 06-30-2004 06:31 PM
800 Aftermarket Gauges FlyfisherMike General IH Tech 0 01-28-2004 02:07 PM
