I'll play.
11.5 city. 14.5 hiway. FI, .030 over bored 345. T-19, 3.73 and 33 X 12.50 mud terrains. built for the trail and constantly loaded with tools and spare parts for the trail. I was getting just a shade under 16 mpg on the hiway with 33 x 9.50 all terrains. Darrell |
Never checked it in town, I put gas in it when the gauge says to, on a long highway trip I can squeeze 18 out of it.
It's got dog tired 304 with a Holley 2300 on it, 727 (POS) 3.08 axle gears and was rolling on pumped up rock hard 31-11.50's, I have a CR T-19 for it and expect the mileage to increase slightly if I ever get the slush"O"matic out of it and the stick in there? It's not a hot rod, if I want to chirp tires and drive fast in traffic I'll drive my Jeep! (my Rambler just SMOKES! the tires!!! )
When my Sll sv345 was fresh (right after I bought it) I got 18mpg highway running on 235 75 Kumos and 3:73 gears.
My plugs were gapped at .065" and timing was 18 degress BTDC, the TQ was rebuilt and it breezed through Ca. smog test. When I went to .035" on the plugs and 8 degress BTDC, the mileage went to 10-12 mpg highway on a good day. Since then, the distributor was rebuilt, module replaced, flex fan replaced the clutch fan, tires are 33"x12.5, still can't get past 12. Hopefully the 3:56 gears will help some.
72 S II with 727 and old/worn 345 with less than 105pounds pressure on each cylinder. 3:73 gears. Just got it back up and running. No idea on the gaps/timing. Still has points and a 4 barrel.
Just filled tank back up... 7.3-7.5 mpg. I'm not happy Oh ya, 33 x 12.5s
1980 SII, SD33T (diesel), 3.07s, 31x10.50s, T19, 26mpg hwy (average). I was getting 22.5mpg when I had 3.73 gears. I also made some turbo and fuel pump mods which bumped me from 25-26mpg a few months back.
78 Traveler 345, 4 speed, 3.73 35x12.50 I get about 12 thats loaded and trail ready.
73 Scout 2 304, 4 speed, 3.73 31x10.50 I get about 10 but I drive it with a heavy foot. |
'77 with a 345 and 727. 3.54 geared 33x12.5s. 12 mpg city 15 mpg hwy.
This might be kind of a silly question, but when everyone switched tire sizes and gears did they also change the speedo gear to adjust for those changes or do you take that into account when calculating MPG?
1973 Scout II 304/727/D20/D44s Due to recent budget cuts and the rising cost of electricity, gas and oil, as well as current market conditions, the Light at the End of the Tunnel has been turned off. |
Where can one get the right gear and how to calculate. Original were 3.54 with stock wheel went to 3.73 and 33" tire, i know my speedo is way out was folling the wife as she drove the scout, she said she never went over 55, while at 65 to 70 i could not gain on her,
| 2300 , 304 , 345 , 727 , axle , diesel , distributor , engine , flex fan , gas , holley , holley 2300 , hot , matic , number , parts , scout , scout ii , size , t-19 , timing , tire , tires , turbo |
| Scout getting good MPG?! WHAT! | ScoutBoy66 | General IH Tech | 11 | 05-11-2010 10:41 PM |
| E85/reg gas Scout mpg comparisons / reports | Paul "Misterfixit" Schulz | General IH Tech | 21 | 07-25-2008 04:33 PM |
| Scout 800 on the highway? | josh felter | Restoration Purists | 6 | 11-18-2006 10:12 AM |
| Gas mileage tips! | Brandon A. | General IH Tech | 21 | 08-21-2006 07:07 PM |
