I was at the local Discount Tire getting my tires rotated and noticed a set of 22s sitting in the corner and for just about 30 seconds I though hmmm wonder how many death threats I would get from fellow binders if I ran those? For $200 a for the set (I buy a lot of tires there so they said $50 for me) I really thought about it for those 30 seconds. |
Got the fuel tank out, looks good inside and out will probably get it coated just to be safe if I decide to try to use it. I will probably just use the Blazer tank as long as I have enough room after the drop and four link.
Pulled the rear axle, no big deal till I tried to get the leaf springs off the axle. ![]() ![]() Broke my last metal sawzall blade, and my 18v impact wouldn't turn the nuts. It was more of a pain to remove those 6 remaining nuts then pulling the motor and transmission.Oh well impact won't be a issue by the end of the week. Got this beauty this weekend so rusted bolts are no longer an issue. Speaking of rust I went to beating on the crud on the rear inner fender well and found shinny white, original color I guess and the first bed rust in the rear most corner right along the seam. This got me curious so I started the arduous task of removing the sprayed on FIBERGLASS bed-liner. I have to say this is the biggest pain in the since I changed the spark plugs in my LS1 Camaro. The worst part of it is I hate how much I love this fiber glass! The bed is in GREAT shape!!! I have only found a few tiny little rust spots in the corners and the dents you see are from my less than patient fiberglass removal techniques. The bed is perfectly straight and I will be able to patch the few holes in no time! I got about a third of it peeled and pried off before it got too cold, not to mention beating on the Scout at 0130 tends to irritate the neighbors.![]() Yes in my haste to get started I forgot to empty the trash, compost pile and scrap metal out of the bed before I pulled it in the garage and removed the axle, Anyone want some yellow Spare rims!? |
I have to say this scout has very little rust and I have to think the bed cover saved it from a lot of damage over the years, but dog-gone-it I have never spent 3 days removing anything from a vehicle in my life. Pick ax, crowbars, grinder, sawzall, GOOD GRIEF!
I found a good bit of rust in the rear driver's side. I figured it was coming by looking under the fender well but it really doesn't look that bad, we'll see the total damage after sand blasting. Slow progress this weekend as I upgraded the lights in the garage and spent a bunch of time tracking down a new frame. I started peeling the bed floor back when I realized this is going to SUCK! Is it best to cut out most and just air chisel it off the frame supports? Please throw a word of experience in there. |
sorry I double posted
Since the Blazer frame was a bust I tracked down a salvage yard that will trade me the blazer sans what I need for a complete s10 frame minus axle for a even swap. YES! I started carefully removing the dash and unhooking everything. My first time pulling a dash, not that tough, just a lot of little 7mm bolts. I have completely given up on keeping this truck old school as it is just too hard to keep it safe and old school without spending a ton of money. Here it is... YOU WERE RIGHT MR. MODERATOR!!! That being said, how many guys do I need to lift the body off this frame? Should I still use the back half of the scout frame or go all S10? I am four linking it and going with factory spring style rear suspension until I can afford bags. I am still hunting the guy who built the bagged s10 frame scout last year. Back to deconstruction (the Blazer), removing the whole wiring harness to make it easier to keep what I want when I do the scout transplant.
When I removed my bed, it was pretty well rusted out. I cut it into 3 sections along the crossmembers and used a combination of drilling spot welds and using an air chisel. It didn't take too long.
| 2wd , 4x4 , body , brake , broke , build , clean , diesel , dolly , door , exhaust , fabricate , front , mounts , parts , photos , rear , rust , scout , scout 80 , scout 800b , seats , top , trailer , truck |
| Scout II Daily Driver / Light Wheeling Build | scoutkid | General IH Tech | 48 | 07-25-2011 08:39 PM |
| scout II daily driver? | Jon | General IH Tech | 30 | 05-15-2002 07:06 PM |
