IH offered a 5 speed overdrive known as the T-34 transmission in those trucks, but they are much more common in the medium duty trucks (Loadstar and Cargostar). Your best option is to order an NV4500 conversion kit from IH Only North and get an NV4500 from a cheby or more likely a Dodge 3/4 or 1 ton pickup from the mid to late '90s.
Wes Van Pelt OneBadBinder.net < My personal IH site with projects and used parts for sale. UPDATED 4/25/11 "Yeah, yours is louder" - Jeff Jamison ![]()
IH has a close ratio 4 speed with a 4:1 first gear.
Do not know how to tell a close ratio from a wide ratio 4 speed -- search this forum. Do not know the years it was used (nnnn - 1980?), but assume it should bolt to your vintage pickup.
73 Travellall 1210 2WD, 392, T-34, 3.73 w/stock Trac-Lok |
if you go the t-19 close route you will want one from a pickup. the the 4x2 scout version usually has the d-20 case adapter and is there fore a couple inches different in overall length.
hth mac
72 1210 WRECKER 392 NON-IC/T-19W/D-60/4.10 73 1210 Travelall 4x4 345/727/D-60/D-44/4.10 powerloc 76 TRAVELER SD-33NA/T-19C/D-20/D-44/3.54 77 SII 392IC/T-19W/D-44/3.54 TRAC-LOC 83 S1754 crew cab w DT-466 service truck various fullsize parts rigs diesel mechanic and hvac tech |
The IH T34 five speed OD transmission will fit in your pickup. You will need the matching bell housing and throw out bearing collar. Your drive shaft will have to be shortened. You may have to get a different drive shaft attachment for the transmission output.
The T34 and its brothers T35 and T36 do not shift as quick and easily as the T19 four speed does. They are medium truck gear boxes in that regard. One caution: You live in CO. If you do lots of hilly driving [Are there any flat parts of CO?], you may find that the large jump between 3rd and 4th gears is a slight problem especially when towing heavy. When you need to go down from 4th to 3rd, the gap is more than 2000 rpm. It is not much problem if you don't tow or haul heavy. Even though I live in a relatively flat area, I removed the T34 and replaced it with a T36 because I haul and tow and the gap was a pain on the hills.
Doc Stewart "Tough Old Geezer" Charter member: IH Old Hippie Club Last edited by Doc Stewart; 10-26-2010 at 11:43 AM. Reason: schpeling |
Speed up the rear axle.
| 110 , 196 , 1967 , 1980 , 2x4 , 304 , 5 speed , adapter , bed , cargostar , conversion , cummins , floor , gear , hose , manual , overdrive , pickup , scout , towing , tranny , transmission , transmission options , truck |
| Manual Transmission + Boggers = MAJOR TORQUE | Rgilpin | Southwest Scouts of Oklahoma | 2 | 01-01-2010 04:14 PM |
| Park/Neutral wire with manual transmission | Rustman | Injection Tech | 5 | 10-16-2009 07:58 PM |
| Automatic Overdrive Transmission For IH V8s | MikeInMobile,AL | BP IH Knowledge Wiki | 0 | 02-20-2009 09:51 PM |
| Loose Transmission mount | SCscoutguy | General IH Tech | 10 | 10-26-2006 07:26 AM |
| '73 Scout II w/ 6cyl. (AMC 258?) options? | JasonR. | General IH Tech | 4 | 11-16-2004 11:50 AM |
