i'll be around to bother ya more now!! ![]() -Jon
1980 Terra Scout II 6.9L Diesel/6.32:1 t19/NP205 4.10 D60's SOA on 4" springs 39x13.50x16 Iroks -'91 Ferd F350 CCLB 2wd dually 7.3 IDI banks sidewinder equipped, ZF5 -'71 Travelette- DT466 power.... -'73 25' Starcraft motorhome --Piles-o-parts-- |
It looks like you got the 1227747 ECM. Nice!
Dive into Bill's FAQ's and have fun reading! |
oh i have read, alot, several times, and plan to much much more!-Jon
1987 5.7 auto. from a 1/2 ton.
Hit up Ragged on ebay for a set of sensors.
-Jon
i'm looking into getting sensors, i'm probably going to run a VSS, i heard it helps when returning to idle at a stop. on the speedo cable under the brake booster is a round cylinder with 2 wires coming out of it, will this work, or do i need GM one? will it go in place of the one on there?
thanks -Jon
i was looking at ragged's parts, what do i need, i see 6 sensors in a set, but i only really need one or 2 in that bunch right? i see the map sensor and spark control (still undecided what i'm doing for a dist....), i still need a temp sensor...and a few others right?
-Jon
ummm, you have the system there so I can't tell you what you need.
You said you are missing sensors and he sells sensors. If you don't want to buy all of them to have spares then just email him with what you need. IMO you should run the knock if you don't plan to burn chips. Compare your parts to the parts required.
Thanks, -Jon
Depends on what one you have.
I'm for cheap and easy.
| 100 , 304 , 345 , 4bbl , adapter , aftermarket , booster , brake , cable , carb , coil , conversion , crank , cylinder , distributor , dizzy , ecm , egr , engine , faq , faq's , find , fuel , fuel pump , gears , harness , holley , idle , ignition , key , kit , parts , pictures , question , scout , shop , solenoid , spark , start , starter , tbi , timing , truck , turn , vss , wiring |
| Noob to site and TBI | Dudewayne | Injection Tech | 6 | 05-19-2010 07:52 AM |
| 89 tbi | rcurrier44 | Injection Tech | 14 | 04-06-2010 01:31 PM |
| Holly TBI question - computer options | Geoff G | Injection Tech | 1 | 10-16-2009 01:57 PM |
| New TBI Swap won't start | mtnrunner | Injection Tech | 6 | 01-22-2008 07:24 AM |
| wiring diagram and ideas | binder man | General IH Tech | 4 | 10-23-2006 06:49 PM |
