Old 10-04-2010, 04:29 PM
kennuck kennuck is offline
Default Timing retards instead of advance
Hi there, I've got a 304 AMC and have done the TBI upgrade using GM 305 v8 tbi parts including 7747 ecm. It has a DUI ignition with an 8 pin module wired in per the instructions on this site. I've read thru all the FAQs and instructions haven't been able to find my issue covered.
The problem is it starts and runs fine but when you punch the throttle it will retard the timing instead of advancing it. I've double checked all the wiring and checked all wires for continuity. I've changed the 8 pin module, ecm, esc module, knock sensor and the problem persists. I'm running out of ideas, anyone ever experienced this and have any suggestions?
Old 10-04-2010, 07:20 PM
EagleMark EagleMark is offline
Banned
Default Re: Timing retards instead of advance
You put the distributor in backwards...
Really I don't know but I would bet you have two wires crossed...
Old 10-04-2010, 07:29 PM
I wish it was that easy! Didn't remove the distributor from the engine. Checked all the wires and had my son double check as well. If you switch the wires from the pick up coil it runs like crap.
Old 10-04-2010, 07:53 PM
Banned
So it's not hooked up to the EFI? Does it still have vacuum and mechanacal advance? Did you buy a tach filter somewhere?
EDIT: Do a search on the forums for DUI. I remember something about this happening before when DUI first made the IH distributor from Chevy parts and it spins opisite of IH. If you can't find anything give Jeff at IH Only a call, or Fleck at Back Country Binders. Something in my gray head says this happened before... they nare both IH parts dealers and have sold these.
Old 10-04-2010, 08:02 PM
No its all hooked up to the efi. Mechanical and vacuum advance is locked down. No tach filter, didn't read where one was needed. I read where guys using MSD needed tach filters, but this is a DUI. Its an AMC 304 btw.
Old 10-04-2010, 08:07 PM
Banned
Got me but I bet Bill knows why in his head without looking...
Old 10-04-2010, 09:20 PM
Bill USN-1's Avatar
Sounds like it working.
Have you looked at the actual timing table to see what it looks like?
Old 10-13-2010, 07:16 PM
I haven't looked at the timing table, not sure what your referring to? I've checked several vehicles with this vintage system and they all advance the timing when the throttle is punched. Could you please explain why you think its working properly?
Old 10-14-2010, 01:13 AM
Bill USN-1's Avatar
What's the BCC(code).
Old 10-14-2010, 06:59 AM
larboc larboc is offline
does it run fine?
is the timing retarding smoothly or does it jump back?
1956 S120 4x4 western plow soon to be EFI
1962±1 stock RHD Scout 80. 152, 4.27 D18 EFI
1980 stock LHD Scout II. Western/Meyer plow 345 d300 t-19 3.31 EFI
1975 RHD Scout II 460 ZF 1356 205 HP60 70 4-link 42's.
I don't get Metros, sorry.
304 , amc , cable , coil , distributor , ecm , efi , engine , filter , find , idle , ignition , light , parts , power , problem , switch , tach , tbi , throttle , timing , vacuum , vacuum advance , wiring
Timing advance? Brandon A. Injection Tech 9 09-12-2010 08:42 PM
152 PCV routing Mastiff General IH Tech 9 11-05-2009 06:02 PM
IH Ignition Timing Advance hofs BP IH Knowledge Wiki 0 03-04-2009 01:14 PM
Distributor Vac Advance mike4514 General IH Tech 6 02-03-2009 05:05 AM
ported vs manifold vacuum for dizzy?? slowboy General IH Tech 5 09-20-2004 12:13 PM
