AZIHR 2015
Old 07-30-2010, 10:05 AM
bogboy bogboy is offline
Default Holley Carb List Number Not Found
I've searched numerous locations including the Holley web site and old car manuals site and have not located my particular Holley List number. I positive the carb is a 2300 but unsure on cfm?
Anyway the Binder part number is 421641-C91
Holley List number is - 6206
71 International 1110
345 cubic inch
Thanks for any insight. Looking to rebuild or purchase rebuilt carb and just want to be sure i get it right the first time. Parts counter monkeys are worthless.
I can post a pic later if that helps.
Old 07-30-2010, 10:15 AM
hacri's Avatar
hacri hacri is offline
Default Re: Holley Carb List Number Not Found
Are you sure about the list # ?
1978 Scout II 304(soon 392)/727/dana 20, Holley Pro-Jection
1979 Scout II 304/t19w/dana 20
1969 Scout 800 Frame
Old 07-30-2010, 02:09 PM
Sure on the list number... here are two pics of the carb with close-up of IHC and Holley part numbers.
ID:	48647   Click image for larger version
Old 07-30-2010, 06:34 PM
Robert Bishop Robert Bishop is offline
Your carburetor is a Holley 2300 model. It was used on some IH light duty vehicles with a V-345 and automatic transmission from 1970-72. Your carburetor was manufactured during the third week of October, 1970, possibly making it the original carb that came on your IH. The original Holley master rebuild kit for it was 85R-3502-S, although this is likely an obsolete number by now. The Napa Echlin equivalent kit is CRB 25529, although this kit may not have a Holley manufactured power valve and needle and seat assembly. I would recommend rebuilding your carburetor. Hope that helps you!
Robert
1972 IH 1210 pickup, 345, T-407
1973 IH 1210 pickup, 392, T-407
Old 07-31-2010, 09:26 AM
Geezz Robert, could you be more thorough???
Great info. Where do you get such?
Old 07-31-2010, 12:41 PM
Holley Illustrated Parts & Specs has much of this information. Holley part number 36-51-7. See the link below.
http://www.holley.com/Store/product.asp?ID=36-51-7
Old 07-31-2010, 02:29 PM
Dana Strong Dana Strong is offline
Posted by Robert Bishop:
When I go to the "Holley Carburetor Numerical Listing", I don't see an entry for his list 6206. I had the same problem with my List 4574 and had to call one of the old-timers at Daytona Parts to get the information about my 2-stage power valve.
Is there somewhere else on this site (Holley) which has the specs for these (his 6206, and my 4574) models?
Old 07-31-2010, 03:16 PM
I am not aware of a detailed source of information about Holley OEM carburetors, such as your 4574 that is online, unfortunately. The only places I could find such info for my List #4313 was in Holley Illustrated Parts & Specs, which is a 440 page technical manual in my possession, as well as the IH service manual.
Robert
Old 07-31-2010, 09:21 PM
At one time, there was a Holley tech service online. If still available, they should have all the info you need.
Bill Bennett 68 Travelall
Old 08-01-2010, 12:50 AM
Months ago, I did call Holley and the technicians there didn't have any correct information about my unit; the information they had was wrong and said my unit was governed! plus they didn't have the correct power valve specs. I did get it from the Daytona people, who have been making their own parts and rebuilding carburetors for long before Holley was sold/reorganized. I've gotten mixed results from a local Carburetor shop; their records seem to be either incomplete, or some employees don't know where to look for some of it.
As I understand it, Holley discarded much of the original books and other data about earlier products, concentrating on racing and performance equipment.
BTW, my unit (List 4574) is listed in my IH manual; it lists jets and such but doesn't have details about values for both stages of the two-stage power valves and nobody cross-references those IH part numbers, (which I do have).
2300 , 345 , automatic , binder , cam , carb , carburetor , holley , holley 2300 , idle , ihc , international , light , manual , master , number , part , parts , power , racing , rebuild , transmission , travelall , truck
Carb swap in pictures, Holley 2210 to 2300. jeffro General IH Tech 40 01-19-2015 12:27 AM
Scout 80 t-152 carb list number??? MattKelley General IH Tech 1 02-20-2010 08:50 AM
Carb ? lwh22 General IH Tech 4 01-05-2007 06:37 PM
Carb problems, one cause I just found... Doug Shailor General IH Tech 2 03-31-2004 12:24 PM
2210 carb - vacuum leak??? ceswanson General IH Tech 5 02-18-2004 07:40 PM
