Old 10-02-2010, 07:37 PM
gregor gregor is offline
Default Re: Build advice
What I did;
- Got the alternator (The monkeys at the counter gave me blank stares when I tried to explain what I wanted, so I just told them I wanted a 100 amp alt from a 1982 Cadillac El Dorado Diesel)
- Measured the gap on the alt for the lower mount
- Made a piece of c-channel, a few inches long, out of a couple pieces of steel angle (I had the angle, but no c-channel. You might be able to find the right size c-channel instead of making it, but it was Sunday, everything was closed, so I just made it myself). Drilled the hole for the alt mounting bolt, and inserted a piece of square tubing across the gap so it wouldn't compress as the mounting bolts are tightened. I didn't take any pictures when I made it, but I attached a diagram of basically what it looks like.
- My Scout originally had air conditioning, and I had removed it. That left a big flat horizontal plate just below and in front of the IP on the passenger side of the engine compartment (does a non-air conditioned Scout have this?) I bolted the bracket to this plate, and mounted the alt to the bracket. This also left a lot more room for adjustment of the power steering pump, but I had to modify the upper PS pump bracket as it used to connect to the alternator.
- For the upper alt mount, I used a turnbuckle, one end attached to the alt and the other attached to a bracket just below the fuel filter that was probably meant for the air conditioning compressor. It would be pretty easy to make a bracket from scratch if necessary for the top.
Now, I can have all my electrics full bore (lights, fans, wipers, etc) and I've still got a solid 13V, but this does put an extra draw on the engine, so it idles slower when I have everything running at once.
1980 Scout II / sd33t
1965 Travelall 1100
Old 10-02-2010, 08:02 PM
watermunky watermunky is offline
Here is hopefully the last disassembly...
And the damage.
Old 10-02-2010, 08:09 PM
Originally Posted by gregor View Post
If it hasn't been done already (I didn't see any mention of this in the thread), convert your brake booster to hydroboost, and you can sell that part along with the stock alternator to some poor soul that needs it. Not only will you have far more responsive braking, you can also then swap your alternator for another that is far less expensive and better at producing electricity.
Another upgrade I would suggest while the engine is out is to consider some sound deadening / proofing in the engine compartment, which can be done with the engine in place but it's much easier when it's out.
I think I might try and tackle the hydroboost. if anyone has any tips I am all ears. I will also probably try to do something about the sound but unless I want to spend a bit of money on dynamat the only thing I can think of is undercoating or rhino lining.
Old 10-03-2010, 07:20 PM
bluescout's Avatar
bluescout bluescout is offline
Send a message via AIM to bluescout
Here's pics of my fab
http://www.summit-pc.com/rob/scoutbracket/
1979 Scout II full of fiberglass and diesel fuel
Old 10-03-2010, 07:44 PM
lindstromjd lindstromjd is offline
Originally Posted by bluescout View Post
Awesome. I think I can duplicate that. Thanks!!
Old 10-03-2010, 07:47 PM
Hydro boost is super easy to install. Only mod I had to make was drilling out the holes in the firewall for the mount, and a splice to lengthen one of the pressure lines.
Old 10-06-2010, 05:33 PM
Another batch of photos uploaded and money downloaded
Here is the new clutch going in the truck.
Clutch disc looks a little different but all the sizes checked out. Any reason this shouldn't work?
And here is the new gauges that will go in the truck.
$180 for clutch, throw-out bearing, and disc.
$230 for gauges.
Not too bad I guess
Old 10-06-2010, 06:42 PM
David Dixon's Avatar
David Dixon David Dixon is offline
$230 for gauges.
Not too bad I guess
In the photo the clutch disc appears to be backwards. Hope it didn't get installed that way.
-D
David Dixon
'80 Scout Diesel - Somewhat modified , currently resting, awaiting a new windshield and new body panels (Like, most all of 'em.)
'78 Traveler, 345, auto, totally stock.
Old 10-06-2010, 07:29 PM
-D
not installed yet. So to double check, the protruding part in the second pic goes against the flywheel?
Old 10-06-2010, 07:52 PM
The protruding side of the clutch disc fits inside the recess in the flywheel, the flat side faces the clutch cover.
-D
David Dixon
aftermarket , air cleaner , bell housing , build , crank , engine , exhaust , filter , front , gauges , oil , parts , plug , pyrometer , relay , scout , scout ii , sd33 , sd33t , spin on , steering , tach , truck , turbo , water
800 Build gmbarker78 Southeast Binders Association 176 09-17-2012 06:45 PM
***** New IH build forum!! ***** Mark Ashford The Skunkwerks 4 01-16-2011 03:06 PM
Performance build -JAX- General IH Tech 7 11-30-2009 07:04 PM
Advice on changing differential tonkatoy General IH Tech 11 05-19-2005 10:48 AM
Cool Project Options need advice Finder-Binder General IH Tech 5 07-11-2003 05:30 PM
