Old 09-13-2010, 08:28 AM
Cal in Carl Jct's Avatar
Cal in Carl Jct Cal in Carl Jct is offline
Default Re: My ’79 Terra Caught Fire & Burned
Yesterday, I decided to change the oil. I got about a quart of coolant out of the pan. I did not notice any on the stick before I saw the coolant or after. I guess I will pull the intake tonight, that is probably where the leak is, that is where a lot of the fire was. I doubt it got the heads hot enough to leak. The 345 has about 108K. My question is, would it be a good idea to pull the heads and have them gone through since I’m so close to them anyway? I'd like some opinions on this...Thanks!
'79 Terra
'79 Scout II
'78 Scout II
'78 Traveler
Old 09-13-2010, 09:01 AM
kennyw's Avatar
kennyw kennyw is offline
It looks like the valve cover did not get hot enough to burn the paint off. I would pull the valve covers and if there is no burnt oil or rust on the valves and springs then clean up the valve covers and put it back together.
1979 Scout 73000 miles
1967 IH Pickup 1000
and lots of parts to build trail rig
Old 09-14-2010, 11:15 AM
In college, I put a new carb on a 59 chevy but used the old rubber fuel line. It ruptured and started a fire under the hood. I pulled to the shoulder and opened the hood then just stood there staring - not clue what to do. A guy stopped and started throwing dirt on the fire, putting it out.
I have done this twice - for other people. Nature's fire extinguisher: dirt.
Old 01-04-2011, 02:48 PM
Hey Doc, Dirt is a good idea for putting out fires! My dirt was on the other side of a tall chain-link fince!
This is just an update of how things are coming along. I ordered two wire harnesses from Super Scout Specialist, one under the hood and one under the dash. Because of the backlog, they thought it would take about 10 weeks till they got mine built. That would make it around the 1st of November. I called and asked, they said hopefully 2-3 weeks more. Still waiting…
Since I ordered a custom instrument panel from The Scout Connection, I had to drop the tank and install a new sending unit to be compatible with the new gas gage. I changed all rubber lines, too. I have held off installing the new DUI distributer, inst panel, and rebuilt thermoquad because I want to install the harnesses first. That’s about it. Oh, I did pull the carpet & seats. I purchased some Dynamat, I think I want to apply that way up high below the wind shield, but I’m not sure how far down to go or even if I will use it. I did caulk all the seams before I repainted, even the rain gutter below the wipers. After all this I still have some rust to cut out, but I just want to drive a Scout again! I sold the one I was planning to keep, had to fix this one…long read…sorry.
'79 Terra
'79 Scout II
'78 Scout II
'78 Traveler
Old 01-09-2011, 12:23 AM
R290's Avatar
R290 R290 is offline
Wow that was a really nice Scout. Bummer
Yep dry chem ext causes mega rust overnight too.
I just bought a ColdFire extinguher to put in my scout. I guess I better hurry up and get it mounted.
1973 Scout II, 345 mill
Old 01-10-2011, 06:42 PM
Greg R's Avatar
Greg R Greg R is offline
My heart sank when I stumbled on this. I'm worried about the Dodge Dart I've got stored in the barn.. But, I found out that other people who also had rodent problems started putting dryer sheets(those fabric softener dealies) in their rigs and that effectively keeps the critters out. So I went out and bought a couple packs. It seems to work so far.
Hope this can help someone else.
69 800
266 V8/4spd & D18TC/OD
4.27 D30/ D44
'56 S110 240 I6/4spd
'71 1210 345 V8/4spd 2WD
'67 Travelall BG246/4spd 2WD
Old 01-10-2011, 07:45 PM
rlogan's Avatar
rlogan rlogan is offline
That must have really hurt. My condolances. It was a fine looking ride.
Old 01-10-2011, 11:46 PM
Thanks to everyone for all the kind replies. This Scout just falls under the category of "more stuff." I have learned again, the more stuff you have, the more stuff you have to deal with.
The fire was a shock at first but now it is on the list of many things that I need to get accomplished.
I did get an update on the wire harnesses that I ordered from Super Scout Specialist. I should have them both by the middle of next week. I do admit I that I will be a little apprehensive when I first turn the key after installing everything.
Again, thanks for all the support!
'79 Terra
'79 Scout II
'78 Scout II
'78 Traveler
Old 02-17-2011, 03:04 PM
Here is an update on my burnt Terra project:
While waiting for the wire harness to arrive I dropped the tank to replace the sending unit. It had to be replaced because the new gas gage that’s in my new instrument cluster, not installed yet, won’t work with the old unit. As you know, the real pain is is not dropping the tank it’s getting them back into the position that you need while applying pressure and guiding the filler and overflow hoses at the same time! On top of all that, it also has a skid plate. The factory location for the wire connector going to the sender unit and the hose clamp to the hard plastic line is really in a bad place (right between the bed & the frame/cross member) so I extended the wire and the hose for an easier removal if ever again. The inside of the tank was really clean, but the out side where the straps were was rusty and close to eating through so I cleaned & painted with rattle can anti rust then undercoated it and the straps with 3M spray can undercoat.
As I dismantled every thing, I put all the hardware in zip lock bags and marked them for easy assembly, however I don’t know where the bolts for my carb went. Can anyone give me the bolt dimensions?
My wire harnesses arrived this past Monday. I’m glad they finally got here I ordered them 6 months ago. I’m happy with how they look, see photo attachments. I thought the under hood harness would include the harness that attaches to the back of the fuse box, and goes forward to the headlights, but I guess not.
I have not been very motivated to get started with installing the harness, but I just have to keep my mind on the end result. That’s it for now…
'79 Terra
'79 Scout II
'78 Scout II
'78 Traveler
Old 02-17-2011, 03:08 PM
The photos didn't post...2nd try...
If they don't post this time I will send them from home, from my Mac!
'79 Terra
'79 Scout II
'78 Scout II
'78 Traveler
bar , build , dash , dead , decals , engine , floor , gauges , half cab , hot , hub , key , limited slip , parts , photos , rear , rebuild , removal , scout , scout ii , terra , top , truck , vacuum , windshield
Scout caught on fire today... Mike Moore General IH Tech 9 08-31-2009 08:45 AM
A/C on/off switch caught fire! Any part number for a replacement? Malcolm M General IH Tech 8 10-02-2007 10:16 AM
Terra cought on fire today Blackdog General IH Tech 6 02-09-2005 11:31 PM
