IC 196, 4-speed, 3.73 gears |
Manual chokes are forbidden in California on a smog check. What is Oregon's take?
1978 Scout Terra 345,T-19 Close,D-20, 3.73 trac-loc, 31x10.50. Tilt wheel, 33gal tank, rust, oil leaks. Past IH's: 1980 Scout II SD-33T 1962 Scout 80 When the mission dictates the form, similarities are inevitable. |
Really? Wow!
I don't think there's any sort of visual inspection here, other than them checking to make sure the cat is there. |
Joey,
It had the generic 31.5" tires, 3.31 gears, a 727 trans. Had all the Ca smog stuff on it, and the engine was in very good shape. I wouldn't drive it over 65 mph. That mileage was on flat land, steady throttle. When I converted over to the TQ, I could get 16, but in the balance I wouldn't go that route if all is working properly with a 2210.
If you have no visual inspection then you just have to pass the sniffer which in most cases for a vehicle the standards are very lienient and if you fail your engine is barely running. See if you can find what the standards are in OR and post them before you go any further. I'm not up to speed on the OR standards and procedures but you don't want to spend a dime on it before you have the test since if you fail you can sometimes get a waiver if you spend over a certain dollar amount on work that is apropriate to correct the particular failure you exhibited.
That's correct Eric, it's just the sniffer test, no visual. It doesn't look like Oregon has any type of waiver program either, it's strictly pass/fail.
Again I don't know about OR but up north here you get a free retest if you fail. Even if it's not free it is likely going to be cheaper than the "full tune up" a shop will likely sell you even though all you need is a 1/4 turn of the mixture screws. |
I don't think I'll have any problem getting it through emissions again, providing I can figure out when it's hesitating off of idle. I just want to get it tuned because I know it should start better, run better, and get better fuel mileage
Oregon could care less.
| 100 , 2300 , 345 , air filter , aluminum , bg241 , cam , carb , cooler , diesel , efi , engine , filter , holley , holley 2300 , lift , oil , performance , photos , power , rebuild , scout , size , top , truck |
| Scout II V8 Air Filter Mod | MikeInMobile,AL | BP IH Knowledge Wiki | 0 | 02-20-2009 08:33 PM |
| 80/800 air filters, fuel filters, oil filters | Foy | General IH Tech | 2 | 09-02-2002 07:31 PM |
| Air Filter Housing | Goatee | Diesel Tech | 0 | 06-19-2002 10:23 AM |
| Performance improvement 101 Breathing | David Lang | Diesel Tech | 1 | 06-05-2002 03:20 PM |
| SD33T Air Filter Part # | Jim | Diesel Tech | 2 | 10-23-2001 04:27 PM |
