AZIHR 2015
Old 06-08-2010, 08:08 PM
Mastiff's Avatar
Mastiff Mastiff is offline
Default Mr. Scout lift springs before and after
I know I really wanted a pic like this when I was deciding what to do. This is with the 2.5" Mr Scout springs plus 4" shackles from IHON. I figure it nets about 3" total lift. I ordered 32x9.5 tires, hope they fit. The tires in the pic say 30" but they measure 29.
1965 Scout 80, D44/D27, 152/T90/D18
Status: Motor, trans, axles, brakes, T-case all rebuilt. Lift and 32" tires installed.
Still need: Skid plates, bumpers, locker(s), winch, better seats.
Looking for: Scout 800 flanged D44, maybe Scout II axles.
Old 06-08-2010, 08:32 PM
Fred Demmon's Avatar
Default Re: Mr. Scout lift springs before and after
I have a 65-80 also.
What was the total cost of the springs and shackles with shipping?
President
Gulf Coast Binders
In order of acquisition
75 SII 304 4 speed
65 80 152 3 speed
77 SII 345 Automatic
75 SII NO engine or trans
74 SII 196 4 speed
76 SII 196 4 speed
80 SII turbo diesel 4 speed
80 SII 345 automatic (parts vehicle)
Old 06-08-2010, 09:14 PM
Mastiff's Avatar
I got the kit which has springs, bushings, U-bolts and shocks. That was $850 plus a little over $100 to ship. Shackles were from IH Only North. I think they were $50 a pair. They are ridiculously heavy duty.
Old 06-08-2010, 09:38 PM
kb'sforme's Avatar
kb'sforme kb'sforme is offline
what else is needed. any shims to corect alignment? or extended brake lines? i know thats not a lot of lift just wondering.
AKA PYRO3256
Wanted 30's-50's IHC COE Truck
1979 scout II
1947 kb-1
Old 06-08-2010, 09:48 PM
Mastiff's Avatar
I put 4* shims, but I'm not totally sure they are necessary. The shackles will change caster for the worse and shims can put it back the other way. I don't think longer brake lines are required, at least not in my case. I'm not sure if my lines are original, but it looks like the shock will bottom out first. I plan to double check all this stuff before doing any serious off-roading though.
Old 06-09-2010, 02:03 PM
guidolyons's Avatar
Good before and after pics
The Scout is lookin' good, post up another pic when you get the new tires on it.
Old 06-09-2010, 02:10 PM
tdc's Avatar
tdc tdc is offline
Looks tuff. Stock Rubber brake lines stretch and blow out. Check them at full articulation.
Old 06-09-2010, 02:41 PM
scorp1us's Avatar
scorp1us scorp1us is offline
Nit-picking, but shims don't correct alignment, they correct caster.
My 4" lift required a longer rear line, but the fronts are ok. I'm still going to replace them though, because my replacements are stainless.
1980 Traveler 345 D44, 3.73, 727, 4" RC SUA w/4* shims, GM 350 TBI (16197427)
Old 06-09-2010, 09:12 PM
Mastiff's Avatar
I was wondering if I should get some longer bump stops with the lift. What do you guys think?
Old 06-09-2010, 09:36 PM
HillRaiser's Avatar
HillRaiser HillRaiser is offline
I have about the same lift on mine and I am running 32x11.50 GoodYear MT/Rs. I get a little rub at full flex, but other than that, they run OK.
ID:	47224   Click image for larger version
1971 Scout 800B Comanche V304/T-39/D20/D30-D44 3.73/POWR LOK/32's/Pertronix/Hurst ProMatic-2/FlowMasters
1961 Scout 80
100 , binderplanet , brake , carb , case , caster , flex , lift , rear , scout , shocks , springs , tire , tires , wheels
