I have a 1983 Patrol, one of very few in the USA. My Patrol is from Germany and came with a SD33 stock. Over a year ago I decided to get going on the engine. I spent some time looking around the USA for a SD33T, tried to decide to just use my SD33, tried to find somebody to do the work. I ended up looking for an engine in Australia. I picked up a 1984 SD33T Patrol in Australia, I wanted to start with a turbo block. A friend of mine and a buider of trophy winning buggies in Oz has handled the build up of my engine and all the fab/mod work. The build up has been going on now for nearly a year. I had this done in Oz for a few reasons...it was cheap and easy to get a whole truck with the engine, I can ship the whole truck with engine to the USA, not a lot of experienced people for this engine in the USA, not a lot of parts for this engine in the USA, nobody I could find or knew that was enthusiastic about what I wanted to do and the build up. I have been to Yuris (the builder) place in Australia and stayed at his house and drove his buggies. So it didn't take much for me to decide to have him do the work. Anyways, on to the engine..... As stated this is a SD33T from a 1984 Patrol. The truck had 300,000kms on it when we started. Engine got torn out of truck, coplete tear down, wash, soak, ect. All parts were ordered for the build. Yuri had recently set up his diesel TLC with a super charger and turbo. I was keen on this. So we planned out the build and mods and this is what we came up with... -full rebuild, high quality rebuild kit, everything new -custom built Garret turbo that boosts low, ect -side mount super charger for pre-turbo boost and no lag off the line -custom built extrenal lubercation system -shaved sump -rebuilt injectors with higher pop pressure -full rebuild on ther IP -custom grind on cam to match new turbo -head shaved, crank ground, ect ect -ported & polished the head -large front mount intercooler and smaller top mount intercooler -custom large aluminum radiator -custom pulley system changing it all to one serpintine belt -high mount alt The oil pump is run from a custom made billet housing and gear set off the front of the IP. The lubercation system runs a 5-stage external pump that is mounted near the side of the IP. There is a pickup in the top of the valve cover and in the sump. Large top mount oil cooler has been used. This engine is going in my 83 Patrol. The Patrol is built up for rock crawling with 16" coilovers, portal axles, ect. You might ask....why do all this to a SD33T? My main reasons were....I wanted to keep as much of the truck as possible Nissan and Patrol. I also like the SD33T, it is a solid engine. I really only want a diesel engine in my truck, I looked into doing other diesels in this truck but in the end decided to just stick with the stock engine and modify it. I wanted to have enough low end power for anything, still be able to do 55mph...I also wanted to be able to run the engine nearly upside down and never worry about it getting lubercated. I am sure you might have questions or comments. Beaware the guy who built this is a fabricator and engineer. Like I say he has built trophy winning rock buggies in Australia of unique design. He has also been a diesel mechanic all his life which he learned from his father starting at age 10. So with 30yrs experience behind him I trust him and his judgement. He did take into account how to run the oil pump off the IP and not mess with timing issues. In fact he spent a lot of time fabbing things and figuring out how to do the whole build. I will answer any questions as best as I can but remember I didn't build this. Here is my truck it is going in.... ![]() here is the engine we started with for the build.... ![]() and here are build pics.... ![]()
more pics...
more pics...
more still....
last of the pics.....
![]() ![]() the engine was started for the first time just a few days ago....here is a video of the first run. not rev'ed up enough for the turbo to kick in. Like I said first run and all! It has now been ran for 10mins or so...temps are perfect so far, oil pressure 40-55psi, no leaks, head bolts re-torqued, valves adjusted, ect ect ect. We have a 4" K&N filter right now and a 3 1/2" dump off the manifold. Eventually it will end up with a snorkel when it goes in my truck. Boost and EGT gauges will also be in it. I should have some more video of it soon once it has been ran and checked more. I will be importing the truck next year then put this engine in my Patrol. My truck is 24v and this engine is 12v so we are going to convert my truck to 12v when this engine goes in. Any ways, I thought you guys might like to see this....
one more video....
I copied and pasted this thread from another one I had on a Scout forum. A lot of people (Patrol owners) ask why do this to an SD33T, obviously it wasn't cheap. I did this to the SD33T for several reason. I did look at putting in a v8, a Cummins and also a newer Patrol diesel engine which is the TD42. In the end I decided to keep the SD33T because it is the heart of my truck. By keeping it with the stock engine I still feel I can call my truck a Nissan Patrol even though the truck is highly modified and most stock gear is gone. Some other options looked to be more costly and also presented a number of problems. I like the SD33T for its simplicity and lack of electricals. Everybody also asks what kind of numbers and power this engine produces. We didn't build this engine just for power increases. It was also built to increase reliability. We also designed and implimented a few things such as a pick up in the shaved sump and the valve cover to make sure the engine can run at all kinds of angles for long periods of time with no worries of lubing. Power increases will not be over 50% due to the 4 main bearing crank. We also are not over boosting the engine. I can give no dyno results for actual numbers until the engine has been ran it. We do not want to rev it past 2500rpms before the first 1000 miles or so. My Patrol is an off-roader. It gets trailered to the trails most of the time. So the engine will never be towing, passing or doing HWY speeds. It will howver see use in the rocks, dirt and water. Currently the engine is still in Australia. It is being shipped over here to the USA this summer, using the 1984 Patrol as a shipping crate! We will then fit it to my 1983 Patrol. Last edited by John Donnelly; 05-20-2010 at 05:34 PM. |
I remember seeing your engine from Binder Bulletin. That has got to be the most ridiculously bada$$ SD33T I've ever seen.
Very nice. I know the focus isn't on super power, but let us know if/when you get it on a dyno
1980 Scout II / sd33t 1965 Travelall 1100 |
Looks great!!
![]() I for one would like to know more about your serpentine belt setup. Carey
There is not much to it really, just some custom machined pulleys produced on a lathe. Here is more pictures of the engine build. http://www.rmp-o.com/phpBB3/gallery2...999&g2_page=45 http://www.rmp-o.com/phpBB3/gallery2...648&g2_page=15 It has been on the dyno several times already. But only to simply test the engines componets and make sure they are working correctly. Once the engine is broken in it will get a final dyno run to see what kind of numbers it is doing. |
| aluminum , axles , build , build up , custom , diesel , engine , external , front , gear , ground , intercooler , oil , oil cooler , parts , pickup , pictures , power , rebuild , sd33 , start , timing , top , truck , turbo |
| The IH Diesel FAQ (with SD33 info) | John Donnelly | Diesel Tech | 3 | 01-28-2007 12:43 PM |
| sd33t naive adapter question... | mark gehlhausen | Diesel Tech | 4 | 03-13-2005 07:47 AM |
| Questions from a new SD33T owner (long) | jdh | Diesel Tech | 4 | 09-07-2004 03:04 AM |
| sd33t Pros...DI versus IDI and More | mark gehlhausen | Diesel Tech | 1 | 08-09-2004 04:12 PM |
| SD33 help... | MQ_Patrol | Diesel Tech | 14 | 06-16-2004 11:53 AM |
