I started out with this hunk of junk...232 I6, D30 front, D44 rear with True-Trac, T-18, Dana 20, 4" Superlift springs and a crappy camo paint job. But for some reason, the damn grew on me. Paid a bit much for it originally ($2200) but I wouldn't trade it for anything nowadays. ![]() Thats when I first got it. Ended up doing nothing more than fixing things as they broke, but I did pick-up a winch for free so naturally I had to build a mounting plate for the sucker to sit on. ![]() Headed off to school and started the rewire when things dictated that since I had an under the dash fire and the rest of the harness looked like hell and I wasn't too happy about it. ![]() ![]() Starting the project I thought it was going to be a 1 weekend cake walk, but things turned out a little differently since I fixed sh!t as it popped up along the re-wire. Picked up the new harness from Jeff at IHON. ![]() Mounted the new fuse block under the dash and started routing wires before I touched anything with the soldering gun. ![]() ![]() ![]() ![]() ![]() She looks a little souless without the lights in. Rebuilt the rear axle with new Yukon gears with an Eaton Detroit for some better traction when I had enough of wiring, besides I had access to a full auto shop at the time and I was getting credits for working on my own junk. Added a new dash from IHON as well, got the autometers from the local Kragen (damn things cost too much)
Its only metal, it puts a good fight but in the end it loses. Remember that. "Its (scout) four-wheel-drive capabilities are equal to anything this side of full tracks" Tetnus, Build in Progress Last edited by okkool77; 04-20-2010 at 07:33 PM. |
While the re-wire was going on, I also bought a new poly tank from IHON since my old one was rusted too hell.
Installed the sucker and ran all new hose to the motor, installed a fuel pump on the frame rail that's a little bit more reliable than the mechanical one that was vintage '71. ![]() Ended up finishing the re-wire job about 6 months after I started and I am happy to say that I've had no more electical fires in the damn thing. Moved to Las Vegas and more work has been done since then. Bought a new Weber 32/36 and installed it, also at the same time I picked up an HEI distributor and dropped that in as well. Drivabillity has greatly improved since those two mods have been done. ![]() ![]() ![]() ![]() ![]() ![]() Now for the current look...No doors and the top will be coming off once I can find a show bar for a decent price as well as the bikini top. ![]() ![]() ![]() Most major work has been put on hold since the apartment complex that I live at has grounded me from welding/cutting/grinding...etc. No work that involves fluids or major parts. However the security guard is willing to look the other way for a case of beer every 2 weeks as long as people don't complain about my "Socially Unacceptable" vehicle as the HOA put it. Future plans include going reverse shackle, SOA w/ the 4" springs that I have now, full width D60 rear with either a D44 front or another D60 front from a Ford. 351W swap with the T-19 tranny and possibly a doubler setup behind that. Now throw some opinions out there and also, what do you think should be done based on the pictures?
Its only metal, it puts a good fight but in the end it loses. Remember that. "Its (scout) four-wheel-drive capabilities are equal to anything this side of full tracks" Tetnus, Build in Progress Last edited by okkool77; 04-20-2010 at 10:24 PM. |
More swimsuit model calendars...most deffnuttlee!!!
![]() If you're going to go with SOB power, I admire your decision to take the road less traveled and avoid the all too boring and overdone SBC route.
Theres a method to my madness with the idea of changing the running gear and motor out from what IH had to start with.
Availability of parts for the motor...much easier with a 351w or 302 than that of an IH sv motor or the 232 that I have now. Same goes for the axles...I can get damn near any part over the counter from any parts store and only a few will they have to order in...makes fixing things when on the road so much easier. But personally from a cool standpoint, I would love to steal Roberts idea and build a bada@@ 304 bored out.
Its only metal, it puts a good fight but in the end it loses. Remember that. "Its (scout) four-wheel-drive capabilities are equal to anything this side of full tracks" Tetnus, Build in Progress |
Got a little bit more done over the weekend, installed a fuel pressure regulator since my fuel mileage had dropped dramatically.
Turns out that Weber carbs like a steady 3psi and no more than that. Picked up the Holley regulator at the local parts shop and mounted it to the inside fender. Hookup was a breeze but it took a little bit more teflon tape than I thought to get the threads to seal. I'm happy to report that the mileage has jumped to around 17.5 around town. Much better than the 12 I was getting with the 1 bbl Holley and a hell ov lot better than the 7.5 I was getting there for a while.
Just had to fix a guys toyota that mounted a weber on it. With the factory mechanical pump it was dumping fuel in the primary and secondary at idle.
Added a regulator at 2.5psi and all was good. reminded me why I hate carbs!!!!!!!!!!!1
What are you having trouble finding for the 232?
Although the 351 will make good power and is a good engine, you could also consider swapping in a H.O. Jeep (AMC) 4.0L (242). It would be a pretty painless swap from the 232 and makes a good amount more power than the 232 and 258, mostly due to the better head design. You could also just swap a 4.0L head onto the 232 for a little increase in power, but a good cam would really make it worth the effort.
1974 IH Scout II | 1972 AMC Gremlin |
But otherwise, the I-6 is good for those who like them. Me, I'm a V-8 guy and I love the power that you can get out of them. Its a personal choice, not the fact that one is better than the other.
More power is a good enough reason
![]() Most DJ5's or older postal Jeeps have the 232, if there's a junkyard near you with anything old in it they're bound to have one. You can also buy a remanufactured or new starter from a few different vendors.
okkool77,
I am in vegas and have been looking for a decent drivers door? Noticed you removed yours. Interested in possibly selling? |
| 100 , 232 , axle , bar , broke , build , dash , distributor , front , harness , lights , paint , parts , power , project , rear , rear axle , rewire , scout , shackle , start , t-18 , winch , wiring |
| Mini Builds-Ups! | Damian Grihalva | D and C Extreme | 10 | 01-25-2012 09:38 PM |
| What Does What? A build for everyday IHers! | Damian Grihalva | D and C Extreme | 57 | 01-10-2012 08:12 PM |
| BOOSTED 345 engine build opinions | cycomick | General IH Tech | 3 | 11-15-2009 01:01 PM |
| Want to build propane (only) 345: | Monkeyplasm | General IH Tech | 46 | 12-08-2008 01:10 PM |
