Thank you all in advance, Mike
RnD Fabrication (404) 954-1660 www.RnDFabrication.com TheDude@RnDFabrication.com From mild to wild, we help your project stand out from the rest. |
4 cyl, 6, v8, or all three?
......__________ .... |__________| .[]<|0|_______|0|>[] ....|.... |.v....|.....| ....|___|.......|___| |
Ideally, we want to test fit with the V8 first as that will probably be the most restrictive. Once we have that nailed down, we can take the prototype unit and mock it up in the others to make sure it fits / see what changes have to be made.
Sounds like you got a lab rat in jetmech. If it doesn't work out, pm me.
We finished up our prototype late last week, and will be getting in touch with jetmech shortly to arrange a time to test-fit and see if any changes are required. Here is a link to our updated webpage:
http://www.rndfabrication.com/Scout800.html And here are some images: ![]() ![]()
Hey, guys - just to give you a status report, we test fit our 80/800 prototype into a rig last weekend and we are getting very close to having this one ready for market. We do have some slight tweaking to do, but we were all very happy with how well it fits so far. We will kepp you up to date with the progress, but in the mean time here are some teaser pics.
Special THANX go out to jetmech for allowing us to use his rig as the test mule. ![]() ![]() ![]()
Will the factory fan shroud be able to bolt up to the finished product?
Thanks, Davis
most-likely not, but we haven't test-fit it to be sure. If Jetmech has one, we'll check when we do the final test-fit after we modify the mounts.
Are you planning on having an electric fan/shroud combo available to fit the 800? Thanks for the info and all the work yall have put into this.
Absolutely! We really like the electric fan option for a whole host of reasons, and we do our best to make that option work on all of our radiators.
| 800 , 800a , body , cooling , cylinder , electric , engine , front , full size , hose , lift , metro , mounts , pictures , power , power steering , radiator , scout , scout 80 , scout 800 , scout ii , scout80 , steering , test |
| Scout II Radiator, Fan and Shroud | THE Dude | RND Fabrication | 64 | 09-24-2012 07:55 AM |
| Scout 800 w/345 and stock V8 radiator? | 350IH80 | General IH Tech | 16 | 03-17-2010 07:23 AM |
| Scout 2 steering box on an 800? | harvey | General IH Tech | 2 | 01-08-2007 08:54 AM |
| Parts for Scout II vs. Scout 800 | GibsonSG | General IH Tech | 4 | 12-18-2006 03:31 PM |
