Old 03-16-2010, 12:57 PM
Roy Purkiss Roy Purkiss is offline
Default 72 travelall dies
I have a 72 travelall that I have been restoring/ working on for about 10 yrs. I have replaced or rebuilt everything. It ran great for about 2 years then developed this problem of dying when out and about and wouldnt start again until cool. The last replacement was a gas line with a rubber gas hose an dnew fuel pickup and float to mitigate clogging. the problem: the engine acts like its starving for fuel after warm up. Ive checked the carb, choke, gas tank, pump, lines, filters (2) and still no joy. I see fuel in the filter by the carb.
392 engine
Edlebrock 4bbl aftermarket (Carter AFB)
auto trans
ac
ps
etc
Any ideas?
Old 03-16-2010, 01:22 PM
Gary Billings's Avatar
Gary Billings Gary Billings is online now
Send a message via AIM to Gary Billings
Default Re: 72 travelall dies
Is it vapor locking?
Have you very carefully pulled the top off the carb when this happens to see if there's any gas in there?
Once warm it doesn't run right? Is the choke working properly?
Just some random ideas that came to mind...
-Gary
El Guapo: Jefe, would you say I have a plethora of Scouts (and two Travelalls and a Pickup)?
Jefe: Yes, El Guapo. You have a plethora.
Old 03-16-2010, 08:40 PM
bindermike's Avatar
bindermike bindermike is offline
Have you replaced the ignition coil? When coils get "old," the spark gets progressively weaker as the coil heats up (when the engine is running). First thing in the morning, it works great, but it quickly goes downhill from there...
It looks like you've got fuel; next time she quits, pull a plug and see if you've got fire.
Good Luck, Mike
Mike Richards - back in the U.S. of A. Hangin' out near our nation's capital.
Enjoyin' my '68 1200 4x2 PU, 8-1/2' std bed, 345, T19A
Old 03-16-2010, 11:16 PM
scoutboy74's Avatar
Closely related to Mike's post, the wrong coil...more to the point...the wrong resistance value can create this problem too. I'll be interested to read the answer to Mike's question.
Trever Whetzel
Fat White Boys
Binder Recovery
& Rehabilitation
SHOP NORTH
4bbl , afb , aftermarket , carb , carter , coil , engine , ignition , pickup , plug , replacement , start , top , travelall
PROJECT: INTL 4X4 - 1968 Travelall 4x4 LeeC General IH Tech 344 04-29-2012 05:49 PM
NY Times Travelall Article Stev187 General IH Tech 2 09-17-2007 11:11 PM
