Old 07-16-2003, 01:17 PM
Bryant Cottam Bryant Cottam is offline
Default Flickering lights
First off this forum is more addicting than . . . well . . . something addicting (insert your other addiction). I love all the help offered here.
Now for the good stuff. When I turn my lights on with my scout at idle they do fine and no problems. However, when I rev up the engine the amp meter guage begins to jump back and forth and simultaneously all the lights begin to go bright and dim in sync with the guge needle. But when I push in the glow plug "trucky" button it stops and they do fine. (yet another use for that astheticaly pleasing "trucky" button) Is this an internal alternator problem or loose belt or what? Any help would be appreciated.
Thanks.
Old 07-16-2003, 01:33 PM
Mike Moore's Avatar
Mike Moore Mike Moore is offline
Default
Your diesel is possessed by the jealous demon of a gasser! You need an exorcist, man!
Seriously, that's odd. This is going to sound generic, but check the ground connections at both ends of the ground cable from the battery to the engine, and also the engine to the frame. It might be grounding back through the glow plug cicuit or sumthi stupid like that. That's odd, though...I'll give you that!
Mike Moore
www.ScoutcoProducts.com
______________
1980 Scout II-Chevy LT1, 700r4, NP241, 3.73's, RS, 4" lift, 31's. Daily driver
Scout LT1 swap: $3055
Leaving a riced out Honda with a fartpipe sitting at the stoplight: Priceless!
Old 07-16-2003, 02:04 PM
John Donnelly's Avatar
Administrator
Default
Clean and adjust your Voltage Regulator as well.
Mike Moore is correct also.
The Grounds on Diesel Scouts are worse than the grounds on Gasser Scouts.
Check the condition of your ground wire from the - terminal on the battery to the connection on the block (should be on one of the motor mount bolts from the mount to the motor itself).
If the cable isn't attached there, attach it there. If your cable is sketchy, replace it.
Make sure the ground stud on the body is connected to the Engine flywheel housing as well. This should be a white ten-gage wire that runs from the body to the housing... it is near the starter.
The voltage regulator needs to have it's contacts cleaned, and the gaps checked and/or adjusted as well.
Keep on Dieselin',
John
Old 07-16-2003, 04:20 PM
Super Mod from Downunder
Default
the brushes in the alternator could also be of concern causing the symptons you describe.
Old 07-16-2003, 05:35 PM
Baradium's Avatar
Baradium Baradium is offline
Send a message via ICQ to Baradium Send a message via AIM to Baradium Send a message via MSN to Baradium
Default
I vote it being a ground somewhere. Bad grounds can cause some weird stuff.
So can plugging up a trailer without drying the connector first when it's raining...
Ryan
'78 SII et al
Old 09-16-2003, 12:16 PM
Default
Well it's taken a while but I have now grounded everything as much as possible with no nonsense ground wires and the the problem is . . . . worse. Yes, that is right worse. However, now I can say the needle bouncing is more responsive and quick. (that observation did not make me feel better at the time).
I am contemplating what to do now. Any suggestions would be appreciated.
Keep dieseln, even if you are a driving a moving strobe light.
Old 09-16-2003, 12:50 PM
Administrator
Default
You should have a good ground from the engine to the battery.
You should have a heavy ground strap from the engine to the body.
THEN....
Run a ten gage wire from the alternator body "E" (for EARTH) to the (neg) terminal on the Battery.
This usually cures the pulsing issue.
Do not confuse the power lug on the back of the alternator with the "E" connection.
Did you inspect your voltage regulator?
Keep on Dieselin',
John
Old 09-16-2003, 05:41 PM
drobson drobson is offline
Send a message via AIM to drobson
Default
I'm with John, check the regulator. These regulators are adjustable, and do have some wear over the years. I had a bad reg in my gas Scout, and it did the same thing you describe. When it would pulse toward "C", the battery was being overcharged, which is bad. Also, clean the connector at the regulator as well. There is also a bullet connector at the starter which is the main feed out of the alternator/ammeter. Check and clean as well. Good luck.
Dave Robson
Former owner of a 1980 Scout II Diesel Midas
Old 09-16-2003, 08:37 PM
Default
thanks guys I will need to run a 10 guage line off the "E" terminal on the battery. How do you check to see if the regulator is good or not? Thanks for any help.
Old 09-17-2003, 07:13 AM
Administrator
Default
Bryant,
Do you have the Diesel Scout engine service manual?
It is outlined in the electrical section.
The manual is CTS-2790, and is available from Binder Books, www.binderbooks.com if you don't have it, which you should.
If you don't, post here, and I will try and get you through it without the manual, but it won't be easy.
Keep on Dieselin',
John
alternator , ammeter , binder , body , brushes , cable , diesel , electrical , engine , frame , gage , ground , idle , lights , plug , power , scout , starter , strap , trailer , voltage regulator
