Any "small spindle" D44 out of a chebbie will work. Look 70's pickups.
-John
I found a Dana 44 axle with disc brakes out of a '71 chevy 4x4 side step it has a 6 lug nut pattern it possible to switch the lug nut patern to a five lug nut pattern? What would i need to do this?
Moser Engineering can redrill them for you. They took my 6 lug front rotors to 5 lug on my Luv.
You just gotta deal with the hassle for the benefits of the end result. But we own Scouts, we already know that... 74 Scout II - 345, 727, D-44's (She named it "Rusty") 76 Chevy Luv - 350, 9" back-halfed 21' Bay Boat |
I did this conversion too, and I'm really happy. I have '73 1110 4X4.
I used the conversion kit from Complete Offroad, including the conversion spindles, Chevy backing plate and calipers and Ford rotors. During the conversion, I uprated the inner axle-shafts to use the bigger universal joints, the Travelall uses the smaller type and there are no stub shafts for that. I had to go with custom inner shafts to match the universal joint's size on the stubs (due to Travelall's oddball length from knuckle to pumpkin). I changed over the master cylinder and booster to Chevy, added an adjustable biasing valve and everything's really sweet. I think the difference in slave cylinders (rear) between the '78 Suburban and Travelall was close enough to ignore. This approach is more expensive than used parts and/or axle swap from another brand, but I got to keep the knuckles, axle housing, connecting rods and drag link original. I seem to do everything the most difficult way, that's our family's motto "Semper Modus Dificillus" I'm really happy with the braking power now, I've never been able to "lock-em-up" with the Travelall before. I'm glad that I made this change away from the Lockeed/Keystone style drum brakes! Un-obtainable drums/shoes, continuous leaking, and bad performance. Can post pictures and parts list and photos if interested. |
A part list would be awesome also if you could maybe list a quick rundown of exactly how you did it would be awesome as this is my first time and I am running blind on it. This site is awesome. I think i am also interested in keeping as much as i can original.
I found that conversion kit. I was wondering if you knew what ratio the front and rear axle are?
| 110 , 4x4 , axle , brake , brakes , conversion , custom , dana 44 , disc , disc brakes , front , lock , master , part , parts , photos , pictures , power , spin on , swap , switch , travelall , universal |
| DOT5, The better brake fluid. | Will Marsh | BP IH Knowledge Wiki | 0 | 05-15-2009 08:01 PM |
| 1961 Scout 80 drum brake problem | bchetrick | General IH Tech | 9 | 12-18-2006 09:01 PM |
| sticky brake problem | twisted800 | General IH Tech | 14 | 12-16-2005 09:35 AM |
| Another Brake Problem!!!! | Cpeters | General IH Tech | 8 | 01-01-2005 07:19 AM |
| brake rotor problem | chris80boy | General IH Tech | 2 | 04-01-2004 02:46 PM |
