Glad to hear your 360 is purring bro! Guilty as charged Bill! After the Moss "got the treatment" (still running your last tune) life took a wild turn... son got license, wrecked my old DD (I've been driving the towrig for *months* ), repaired the car, found a replacement DD for myself, lost several months hunting whitetail, and went thru 3 regime changes in my management chain (a 1.5years of 60+ hour weeks)...BUT, I'm back & hope everyone is doing good? ![]() Quote:
We didn't get much done today... Since last night, did engine/tranny/rear axle fluid changes & reinstalled the mufflers the PO hacked off the Mustang. We did run down a few small things that were missing (knock sensor, 2wire EST connector, & some fasteners), & Tater (my brother) removed a few remaining items & installed the fuel pump blockoff, and continued to discuss layout (I'm leaning towards a cut/solder/heat shrink scenario, because he just doesn't have the room to back pull/bundle the "extra" 7' of harness!). He took the adapter home to finish a couple holes & will blend the bores tomorrow... while I undertake a heater core in the Foxbody
'72 "Mossy Edition" Jeep Commando, TBI 304/TH400/D20, SOA D30(Detroit EZ) & D44 (welded) w/ 4.27s & 33" Swampers, "selfmade" bumpers, 8K# Winch, Full Cage, & folding windshield |
I found that by the time you tailor each wire down to the right length it doesn't leave many. So I normally just cut the harness and do them all.
Just make sure to heat shrink each when done. If you put all the slices inside the cab it will cut down on problems with water.
I found a cap from a Cadillac with a 4.3 it worked pretty well.
Hi Dave,
I took some pics today for you. I mounted the Map EGR filter and ignition modual on the valve cover, comp in the glove box,The Temp sender in the place that my CTO switch was mounted.In your photo it looks like yours is in your manifold. I didn't get the knock sensor out of my 4.3 and I am kicking myself for it. I tried the resistor trick but it didn't work for me. I also had to change the air cleaner "clocking" to avoid hitting the radiator support rod. |
THANKS for the pics Sheldon!
![]() I haven't looked *real* hard, but didn't see a hole for the KS...
Dave,
Glad to help/share ideas. I like to see other rigs and they're solutions. for the KS. I was thinking about drilling a hole in the fuel pump block off plate, or tying it up into the wiring harness and just grounding it to the block with a wire. The old coil bracket makes a good fuel pump bracket. good luck! sheldon |
Sheldon,
I haven't seen you posting since the frankenjection. Are you done or just hanging out with the jeep guys?
Hi Bill,
Sad to say My project has been put on hold till spring. My wife has been having her hips operated on. The last one at Christmas. with two kids 4 and 7 that leaves little wrench time. Also the detroit locker does not mix with the snow covered roads well. I made my cable and looking for a lap top. I have been reading post but my knowledge is somewhat limited. Besides you are sooooo good at typing " didn't you read the FAQ's ". This IS the only 4x4 forum I am a member of. I will post if I can help someone, or update my project. Now stop hijacking Dave's thread or I'm going to tell MOM. sheldon |
I see no reason to have to retype everything when the basics are all there. I may not be the best writer but I think they are pretty easy to follow if someone just reads them.
I agree 101% my goal is still to post a desent BIN / LOG without asking a question! Thanks Bill
sheldon |
| 2bbl , 304 , adapter , axle , broke , cable , cage , carter , cracked , ecm , engine , front , harness , mount , panels , parts , photos , radiator , rear , springs , start , tbi , throttle , trailer , wiring |
| Manifold adapters for TBI | Bill usn-1 | Injection Tech | 27 | 06-28-2011 12:29 PM |
| TBI running wayyyyy toooo rich | 65chevy4x4 | Injection Tech | 16 | 07-15-2007 12:40 PM |
| AMC 258 Tbi, which chip? | 73jeep | Injection Tech | 2 | 07-04-2007 07:52 AM |
| Christmas in September.... Affordable's TBI kit is in hand! | Damian Grihalva | General IH Tech | 17 | 09-27-2004 12:20 PM |
| AMC 258 I-6 carb question | dbongo | General IH Tech | 17 | 01-16-2004 09:39 PM |
