Old 02-16-2010, 11:48 PM
Will Courtney Will Courtney is offline
Default sun shades?
anybody know where to get NOS or new sun visors? Or is there anouther make of vehicle that would work rite size wise? I mean the ones you flip down to block the morning or evening sun, not the extension on the wendshield frame. Mine are pretty ratty and the hardwar is pitted and cruddy looking.
Thanks
Old 02-17-2010, 10:48 AM
Robert JetFxr's Avatar
Robert JetFxr Robert JetFxr is offline
Default Re: sun shades?
Phil Coonrod 303-838-8505 Great Scout resource
Robert AKA Jetfxr
RIP Ricky you are missed.
Did you check the green wire?
1973 Travelette ton axles on 35s
1977 SSII Just a little modified ;o)
1980 Scout with 375hp LS1
Old 02-17-2010, 12:35 PM
Thanks, soon as I get back state side I'll give a call.
Old 02-17-2010, 12:56 PM
truck mechanic truck mechanic is offline
I used a set out of a caravan, but had to change the end that screws to the windshild frame.
Old 02-17-2010, 04:01 PM
Ray Cass's Avatar
Ray Cass Ray Cass is offline
Paul,
This would be a great topic for you to write up. If possible, I know there are alot of folks that would love to have this info.
Ray
Triple Diamond Fourwheelers
www.triplediamond.org
1980 Traveler Turbo Diesel "Black Beauty"
1974 Scout II 258 I6 "Ole Yeller"
1962 Scout 196 "Sarge"
Old 02-17-2010, 06:31 PM
Dana Strong Dana Strong is offline
I haven't looked at the sun shades in my Scout in a long time, but recall that the 'cloth' shade part just slips onto the steel rod, as with many older vehicles. I'd suggest that the hardware might be easier cleaned and refinished than replaced, and a newer shade found which fits it. At worst, how hard would it be to make a new shade from scratch? Silkscreen the top side with an old ad from IH, or Warn, or Dana-Spicer to add some uniqueness to it!
Old 02-17-2010, 10:02 PM
Scott Hickman's Avatar
Scott Hickman Scott Hickman is offline
FWIW,
Sun visors can be recovered by interior shops, the kind that do headliners and convertible tops etc. Check your Yellow Pages for a local shop.
I also see IH sun visors on ebay frequently.
My .02
1975 "200" AWD
Western North Carolina
SEBA / Southern Scouts
Old 02-18-2010, 08:30 AM
JasonR.'s Avatar
JasonR. JasonR. is offline
If you're not worried about having the OEM visors, try to find a set from a Jeep CJ/YJ/TJ Wrangler up to about 2005 model year.
They slip slip right over the stock Scout visor arms. No need to remove the arms/brackets from either the donor Jeep or the Scout recipient. Just slide them off and on.
If you want new they're around $50/each from the Jeep dealer. I had my choice of several colors from a local salvage yard for $10/pair.
Best part is they are actually not as tall as the IH visors and don't block as much of the Scout's already short windshield as the OEM ones do.
HTH,
Jason
JasonR.
Old 02-18-2010, 11:28 AM
That's what I had planed, but the metal is pretty pitted. I've got an old traveler that I might be able to use the metal parts off of, I'll have to check.
Thanks
Old 02-18-2010, 09:40 PM
ihscoutmatt's Avatar
ihscoutmatt ihscoutmatt is offline
HTH,
Jason
is this for a SII or 800 or both? my SII has good ones, but my 800s now thats another story
Matt Robinson
Malvern Ar
'79 Scout II 345/wide ratio t19/dana 300 4:1
and lots of parts and parts trucks
800 , colors , frame , info , part , parts , scout , scout ii , screws , size , swap , top , travelall , wanted , warn , windshield
sun visor's El-cheapo Restoration Purists 0 12-22-2006 08:03 PM
scout 80 sun visors? MattKelley General IH Tech 3 07-08-2006 07:41 AM
installing a Sun super tach II wfleming General IH Tech 2 03-13-2005 07:18 PM
Snow run PRE-run... Sun Nov 23! binderbound IH Scouts & Trucks of Oregon 13 11-25-2003 06:25 PM
Sun visor loose GregF General IH Tech 6 11-12-2003 05:17 PM
