Old 12-09-2009, 08:21 PM
gmbarker78's Avatar
gmbarker78 gmbarker78 is offline
Default flickering gauges
I have a 79 Terra, the gauges come and go. I'm thinking it's probally a ground issue. Sometimes they just flick on/off and sometimes they stay on/off. Bumps also seem to influence these actions. My questions is where are the grounds I should check? I really don't want to pull the dash unless I have to.
Thanks, Gary
67 800 Limited GRC Edition, 266/T-19W/D300
79 Terra Rallye, mostly stock driver
61 Travelette, KOH Chase inspired build...........one day!
1250 Cub Quietline
Old 12-09-2009, 08:50 PM
Dennis Bernth's Avatar
Default Re: flickering gauges
The screws that mount the gauges in the dash are the grounds. If they're undersized, or loose, that could be the problem.
Old 12-09-2009, 09:39 PM
scoutboy74's Avatar
Other problem areas on these My-T-Fyne instroomints are the ultra-frail pin connectors on the circuit boards where the plugs connect. They can get loose and wiggly. Also the retaining nuts that secure the gauge studs to the circuit boards can loosen over time. Time to tear that instrument panel apart! It's not that bad. Why, if Dennis and I had a dollar for every time we've done that job, we wouldn't be too old too work and to poor to quit!
Trever Whetzel
Fat White Boys
Binder Recovery
& Rehabilitation
SHOP NORTH
Old 12-09-2009, 10:12 PM
lev1a's Avatar
lev1a lev1a is offline
Edit................... Not pertaining to gauge lights... duh
http://oldironoffroad.com/
Old 12-09-2009, 10:23 PM
Allan E's Avatar
Allan E Allan E is offline
Most likely there is a loose wire feeding the CVR. The ground in this circuit comes through the sending unit. Since all are affected, it's very likely to be a loose hot feed somewhere.
Charter Member, IH Old Hippie Club
Charter Member, SUV Recovery Team
Fell off IH turnip truck, run over several times.
Old 12-09-2009, 11:08 PM
scoutboy74's Avatar
While you're in there that far, might as well gut all the gauge pod buckets and make a very simple, but very worthwhile upgrade. IH must have gotten a fantastic deal on sky blue paint. That's the only reason I can think of for why they painted those buckets that color. Some time back, a government subsidized research group...the name of which escapes me...did a double blind study regarding the reflective and refractive characteristics of that shade of blue. After years of meticulous research and billions of dollars spent, they concluded that sky blue doesn't really reflect incandescent light all that well. True story. So in "light" of that startling revelation, you may want to consider squirting some chrome, silver, or even white paint on the inside of those cans. I did, and the difference...well, let's just say it's night and day.
Trever Whetzel
Fat White Boys
Binder Recovery
& Rehabilitation
SHOP NORTH
Old 12-09-2009, 11:43 PM
Steven67fr's Avatar
Steven67fr Steven67fr is offline
I have had that problem as a result of the ignition key switch. It had to be in just the right position for the gauges to work. Changed the switch and problem was solved. (though, if your ammeter is affected as well, it probably isn't this) I very frustrating problem to figure out, since the first thought would be the gauges, grounds, and things immediately surrounding the gauges. Couldn't hurt to check.
1967 1200B 4X4, 304, T-98, NP202, Dana 44HD (FA15) and 60 (RA17)
1968 1100C 4X4, 265, NP202, Dana 44's (FA16 front and FA18 rear)
cvr , dash , flicker , gauges , ground , grounds , ignition , key , light , lights , mount , paint , panel , poor , screws , switch , terra
Generic fuel sender and SW gauges questions ollie Triple Diamond Trucks 5 10-08-2009 03:12 PM
Scout II Instrument Panel Fabrication and Installation with Aftermarket Gauges MikeInMobile,AL BP IH Knowledge Wiki 0 09-27-2009 07:20 PM
New gauges for Scout II your dash!! RogerH IH Scouts & Trucks of Oregon 8 09-30-2007 03:38 PM
Looking for some gauges for IHOH Colin Rush IH Scouts & Trucks of Oregon 2 10-13-2005 07:07 AM
