Old 12-03-2009, 10:59 AM
Scott H's Avatar
Scott H Scott H is offline
Default stop leak, bad for your engine
I fixed a truck(not ih) that some one used stop leak in instead of fixing it right. I've ran across this more times than not with this type of product, bad stuff. If you must temp patch a cooling system use an egg or black pepper, works as good and doesn't do this to you head gasket. The stop leak was only in this engine for about a year too.
Scott
73 Scout XLC
79 Traveler(Wife's)"Part Postal"(resto~mod in progress!
66 Cub Cadet 123 Working GT
66 Cub Cadet 123 parts rig
Think off-center.
George Carlin
Old 12-03-2009, 06:41 PM
ScoutBoy66's Avatar
ScoutBoy66 ScoutBoy66 is offline
Default Re: stop leak, bad for your engine
does this really do this?? i just put some in my scout 66 with a 345** but it can really eat head gaskets like that? hmm i really need to gey my radiator patched.
1966 scout
currently V-8 swap 345ci
*Bondo* Edition scout
Old 12-03-2009, 06:47 PM
sullyscout77's Avatar
Thanks for the tip, Scott!
Keep 'em comin!
1978 Scout II, 304, T-19, DANA 44/44/20, (Mrs. Sully's), "TOWANDA"
1960 B120 Travelall, 4X4, 3/4 ton, "WILBUR"
Sully
Old 12-03-2009, 07:37 PM
IHWILD IHWILD is offline
Send a message via ICQ to IHWILD Send a message via AIM to IHWILD Send a message via Yahoo to IHWILD
I'd hold out for more scientific proof as least for IH motors. (Don't we run steel gaskets?) As I've put more then my fair share of that stuff in my truck and it has been running as a daily driver for over 5 years since I know I last put some in. Without a single issue related to heads or other coolant areas. I do have some leaks under the intake manifold but it's probably due to age anyways. (The welch? plugs)
Just my observation so maybe I'm just a lucky one.
Rich
1979 Scout II 345 Auto 4X4 2in skyjacker, 2in body, 31X10.5X15, Rollcage, rattle can paint. Also roughly 13 other Scouts, 1 Travelall at my dad's some for restoration, some for parts hehe others ummm.
Old 12-03-2009, 07:49 PM
ktsno1's Avatar
ktsno1 ktsno1 is offline
Send a message via AIM to ktsno1
been in mine for going on 4 years and no problem...
75 scout II XLC 345, 2brrl, T-15D, Dana 20, Dana 44's, Metalic blue paint, soft top, cd, cb, CJ rims.
68 Scout 800 266 4speed. hard top. d44 rear skid plate,some body work to make it legal, cherry bomb duals, tracker gas tank in rear, cheep bedlinered outside.
Old 12-03-2009, 07:51 PM
Paul Morgan Paul Morgan is offline
Banned
That damage was probably already done, Stopleak or not
I like the egg trick better than Bar's Leak
Old 12-03-2009, 09:09 PM
Fred Demmon's Avatar
I am with IH wild
I have used the stuff many times in my younger days. Never had a problem.
That being said. I think that fixing it right is a much better idea
President
Gulf Coast Binders
In order of acquisition
75 SII 304 4 speed
65 80 152 3 speed
77 SII 345 Automatic
75 SII NO engine or trans
74 SII 196 4 speed
76 SII 196 4 speed
80 SII turbo diesel 4 speed
80 SII 345 automatic (parts vehicle)
Old 12-03-2009, 09:37 PM
R290's Avatar
R290 R290 is offline
I've seen that on aluminum head and cast iron blocks. The Bars leak drops out in the engine block near the freeze plugs. I open a few motors and wash a cup or two of that stuff out. If the radiator leaks and your not going to fix it, just remove the radiator cap, then you will have no pressure
1973 Scout II, 345 mill
Old 12-04-2009, 04:54 AM
Since coolant and therefore stop leak couldn't touch that gasket where it blew out I can't blame the stop leak. That damage is more likely from overheating and detonation or warped head. Most people don't check coolant until the engine overheats then top it off, find a leak and add stop leak. Un fortunately the damage is usually done by then.
Old 12-04-2009, 11:03 AM
Scott H's Avatar
I never said it happens to EVERY engine, but it does happen to a lot of them. This gasket blow out had nothing to do with warped head or over heating. I ended up replacing the rad, heater core and water pump. The water pump had the fins eaten off by the stuff and the heater core was plugged up from the stop leak. I worked in a shop for 18-20 years, this problem is common with stop leak products. You can use it if you want, but it's a crap shoot if you do.
Scott
73 Scout XLC
Think off-center.
George Carlin
345 , aluminum , bar , cap , coolant , cooling , engine , events , glass , head gasket , overheating , radiator , scout , truck , water
9 Liter Engines International-9.0 Diesel Tech 32 04-25-2013 08:53 PM
392 oil filter adapter leak on new engine 2tontruck General IH Tech 2 02-10-2009 10:04 PM
old timers trick for stop leak? binderbart General IH Tech 15 03-22-2004 12:11 AM
bad engine block or what George Struther General IH Tech 8 02-05-2002 10:56 AM
engine stop mechanism 17yroldScouter Diesel Tech 1 01-23-2002 09:58 AM
